Question about Brother P-touch PT-1280 Thermal Label Printer
No cassette error P Touch 1280 - Brother P-touch PT-1280 Thermal Label Printer
I would like owner's manual for the brother model #PT-1280,printer
You can go to brother-usa.com and click on the "support" tab, then scroll down a little and you will see "manuals". Click on that and enter the model # and you should be able to download the manual.
Jun 09, 2011 | Brother P-touch PT-1280 Thermal Label...
Brother PT1280 P-touch Machine User's Manual Download
You can download and print the instruction manual in PDF format from Brother PT-1280 support website by clicking this link
On the page which opens, click on the 'Download' button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader. Thanks for using FixYa
A 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Brother P-touch PT-1280 Thermal Label...
Brother HL 1280
is the actual model is Brother PT 1280 .. it';s a labeling p-touch..if yes..then you can download the user manual here...
http://www.brother.com.my/my/productDetail.asp?model=PT-1280&Rnum=241294
May 24, 2010 | Brother HL 1260e Laser Printer
My PT 1280 won't cut. Can I get a new blade?
The parts list doesn't show a blade alone, part # LN6775001 is the cutter lever, could be what you need. About $3.00
Jun 23, 2009 | Brother P-Touch - PT-1280 - Home and...
Error in A3 print
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Aug 30, 2008 | HP DeskJet 1280 InkJet Printer
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Card error cassette error
A common fault, take it back to the shop!
Dec 25, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Brother P-touch PT-1280 Thermal Label Printer Logo
258 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
