Question about Logitech diNovo Edge 9676850403 Keyboard
New battery pack search
Hi -
A full charge will last as long as it deed when new (if keyboard is left on overnight, it will require a charge again)
Need to install a new battery pack. Would you know where I can aquire one?
Thanks
  • abarone300 May 13, 2008
    Sorry, I meant it will NOT charge as long as it deed when new. And I would like some infomatio as to where I can ACQUIRE a new battery pack. Also some instructions on how to take the thing apart, would be nice, can't see how, ( I see no screws...) believe it or not, I do this for a living!
    Thanks
The screws are on the back under the orange cardboard cover.
The battery is a Li-ion 930mAh 3.7V
190304-2004 R-IG7
L/N: K44B
The brand on the battery is logitech.
Posted on May 25, 2008
I have ZTE Jack 3G.it wont charge till full even when left overnight only to find it not full and continues charging.please help me with his issue.
It sounds like the batteries are dying. A short in the battery pack will give problems like that. Replace them.
Jan 13, 2013 | Cell Phones
Tip
New Laptop Battery Use Tips
Taking Care Of Your New Battery Pack
Normally, a new battery pack comes in a very low charge condition and must be fully charged before use. Refer to the user manual of your portable electronic equipment for charging instructions.
A new laptop battery pack needs to be fully charged and fully discharged or “cycled” as much as five times to condition them into performing at full capacity.
Your equipment may report a fully charge condition in as short as 10 to 15 minutes when the new battery pack is being charged for the first time. This is a normal phenomenon especially for Nickel Cadmium (Ni-Cad) and Nickel Metal Hydride (Ni-MH) chemistries. When this happens, remove the Dell xps m1530 Battery pack and let it cool down for about fifteen minutes then repeat the charging procedure.
“Conditioning” (fully discharging and then fully charging) is necessary so as to maintain the optimum performance of a battery pack, and is recommended at least once a month particularly for Ni-Cad and Ni-MH batteries. Failure to do so could result in reduced charge capacity and can significantly shorten the battery pack’s useful life. Lithium Ion batteries do not require conditioning.
It is normal for a battery pack to get warm when charging and during use. However, if the dell Inspiron 2650 Battery pack gets excessive hot, there may be a problem with the portable electronic equipment’s charging circuit and should therefore be checked by a qualified technician.
Rechargeable batteries undergo self-discharging when left unused for long periods of time. This is normal particularly in the case of Ni-MH and Li-Ion chemistries. For best results, always store a battery pack fully charged. It should be removed from the equipment and kept in a cool, dry and clean place.
The amount of runtime a dell inspiron 8600 battery produces depends on the power requirements of components in your electronic equipment. This could be the hard drive setting, screen intensity and back-lighting on notebook computers, the liquid crystal display (LCD) screen and floodlight feature in a video camcorder, or the tri-mode communications network of a cellular phone. Always refer to your equipment’s user manual for power management settings.
on Apr 20, 2010 | Computers & Internet
Tip
Better Battery Life Span
Rechargeable batteries can be maximized to its usage.This pertains to mobile phone re chargeable batteries. If the uses reaches to the point wherein batteries are easily drain. You can solve the problem and resuming back the batteries to its normal capacity and performance.HOW? You need to put your old batteries in a freezer for an overnight. But before doing this, you need to be sure that your battery is in an empty status.
1.Pack it with a newspaper or a masking tape and be sure that it is fully packed that no water can wet the battery.
2.Put is inside the refrigerator freezer and let it stay overnight or at least 8 hrs.
3. After doing no.2 Remove the packing and let it dry under the sun. make sure that it is fully dry.
4. Charge the battery for at least 6-8 hrs.
5.Then the battery will resume its full performance as good as new
You can now use it in your phone again.
on Apr 08, 2010 | Cell Phones
I just got a brand new uho78sx, put it in the charger dock after about 3 hours the light went of indicating that it was charged but it would not turn on. When I put it back in the dock the charge light...
It would seem that your battery pack is Ni-Cad, if so, these have a memory, this means they will only recharge from the last top-up, rather than complete charge.
You need to completely drain the battery pack until it is flat, as in no charge left.
Otherwise, buy replacement Lithium Iron (Li-On) battery pack from Uniden or on ebay, these don't have that memory effect the Ni-Cads do, so you know you won't have these problems again.
If it's a really good radio, then replace the battery pack with really good one.
I hope this has been helpful.
Regards,
Peter
Nov 16, 2011 | Uniden Radio Communications
Hi there i just bought ASUS,X42 series laptop but it seems the battery can only last for an hour.please i want it to last longer,how many hours should charge cos it a new o laptop i just bought..thanks
The battery should be charged overnight ie for approx. 10 hours.
When the battery runs down then charge it up again until it is fully charged, you may need to do this several times until the battery reached it normal capacity.
Jul 23, 2011 | Computers & Internet
Hi my xbox wireless controller that came with the
Particularly in first person shooters, pressing the right trigger fires your weapon, causing your controller to vibrate which in turn may cause your battery pack to pop out if not properly seeded in the holster. Make sure your battery pack is fully plugged in and clicked into the battery compartment.
Also make sure your battery isn't bad. If you're using a rechargeable battery pack, it is quite possible that the pack went bad on you. Try charging it until it's indicated full by your charging device and try it again. If you're using AA's, get some brand new ones and try again. If the battery pack isn't working after charging it, you might need a new pack. The battery life indicator on the console isn't very truthful when telling you your total battery life left.
You can also try taking a standard pencil eraser to the battery coils in the controller to try cleaning them. The rubber eraser will remove any stuck on debris. Use it on the battery too, just in-case problematic debris is on the battery side.
Jul 08, 2010 | Microsoft Xbox 360 Wireless Controller
I've owned this great little Black and Decker CST800 grass trimmer for 6 years and only use it in Montreal summers (5 months long). Just this past week, I brought it in to recharge it and left it for 5...
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
Jun 15, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Logitech diNovo Edge 9676850403 Keyboard Logo
655 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
