Question about LG WM-2277HW Front Load Washer
HELLO, we washed clothes and the soap would not clear and the clothes were still water logged. Now in trying to fix it, it will not drain, Not sure what to do terri
  • 1,543 Answers
Drain the water out by using the small hose located behind the access panel on the lower left side of the washer's front panel. After removing water, un-screw the big knob to the right of the hose and pull it out to check for blockage in the filter. If blockage found, remove and re-try cycle. If no blockage found in filter, replace pump motor.
Posted on Sep 07, 2010
Downy goes first than soap
I fill the washer with water first
Then open the lid put in the soap
3/4 cap full,then then 2/3 cap downy
(Both together-bleach as well- if a white load)
I add only to clear water after it fills
Then allow the water to mix the soap
Then add the cloths a few at a time
NEVER put the cloths in & add soap
on them with no water or use the silly
places on the top they say to add stuff
You only add soap etc to plain water &
no cloths & mix first,then cloths go in
Common Sense as to what is taking place
The part about the softener was just silly
It is in the water mixed with soap etc & all goes out
at one time
It is a one step deal
Water,Soap,Downy,then Cloths your done
Nov 04, 2014 | Samsung WF337AA Front Load Washer
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
May 03, 2017 | LG Washing Machines
Have residue on most to all clothes. i thought it was a water softner problem but that is now fixed. any ideas?
Residue is almost always soap related.
1: Soap goes in the washer first, then clothes. The other way around leaves soap on clothes.
2: switch to concentrated liquid soap. This blends better with cold water.
3: Dry soap has cardboard fillers. Cheaper soap has more fillers. Try a better soap brand.
4: The washer may have build up inside and may need to be cleaned out. (not likely as this clears up real fast)
Apr 03, 2010 | Washing Machines
My Maytag neptune washer has a bad odor that seems to be transfering to the clothes. What can cause this and how do I correct it.
on the front load machines there is a large rubber door boot which gets built up with soap scum. always leave the door open a little bit when the wash day is done. there is a product available called "Afresh". it comes in a pkg with 3 tablets. if the odor is strong follow the directions and use all three tablets. then for maintenance use one tablet a month in an empty machine. what also helps is to make sure you do at least one hot water only wash per month, this helps to disolve all the soap that gets built up in the dispenser tubes and drain hoses etc. hope this helps.
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smelly water does not completely empty
Hello.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
  • Thank you for usning fixya.
    Jul 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    GE Top Load Washing Machine -- Agitator will not cycle
    Agitator's don't spin on wash cycle.
    I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
    Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
    Jan 26, 2009 | GE WBSR3140DW Top Load Washer
    Suds residue left on clothes just washed
    ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
    Nov 27, 2008 | Washing Machines
    Softener slot won't drain.
    take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
    Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Where's the soap going?
    Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
    During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
    Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Fabric Softner section won't fully drain....
    This video will show you how to keep your soap draw clear and how to service the parts
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
    LG WM-2277HW Front Load Washer Logo
    102 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
