Question about Toys
8995 mlh1 milan simplicity crib instructions - Toys
slave2aslave
  • 302 Answers
SOURCE: Simplicity crib manual,8995MLW
Certain cribs are going to the crypt. Simplicity Inc. is now out of business. As of July 12, 2009 at least 13 children have died in cribs and basinets recalled by Simplicity.
Because of this I am having trouble finding ANY of the manuals from simplicity. I'm sorry.
Posted on Sep 24, 2009
slave2aslave
  • 302 Answers
SOURCE: I need crib parts for Simplicity....Milan Crib n Changer Combo
Because of this it may be rather difficult to find...sorry.
Please check to make sure your's isn't one of them.
SOURCE: I have lost the instruction manual on how to
If you find a solution, PLEASE post it... I have the same problem with the same model....
Posted on Feb 03, 2010
ZJLimited
  • 17970 Answers
SOURCE: How do I convert my
Check this procedure...
1 Remove the front panel of the Simplicity crib. Use the Allen wrench provided with the crib (you should have stored the wrench and extra bolts in the pouch under the crib when you first assembled the crib). There are two 45mm bolts on each side of the front panel.
2 Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3 Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4 Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5 Store the front panel of the crib carefully. Wrap it in blankets to prevent scratching. The front piece can be used later to turn the toddler bed into a full-sized bed.
Also, could check some recals in THIS LINK.
Hope helps.
Posted on Oct 18, 2010
mkd123
  • 41 Answers
SOURCE: need instruction manual for simplicity model 8995
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
Here's one of the top rated:
mkd123_1.jpgGraco Sarah Classic, 4-in-1 Convertible Crib
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Posted on Jan 29, 2011
Need instruction manual for simplicity model 8995 4 in 1 convertible crib
Good Luck.
Jan 17, 2011 | Simplicity for Children 4-in-1 Convertible...
Which drop side models are on the recall list?
The following model #'s are involved in at least one of 6 different recalls issued for Simplicity brand cribs.
  • Recall due to chipping paint: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recall due to mattress support issues: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recalls due to drop-side issues:
  • 8910, 8050/Serial Nos. 3005Y to 0806 HY
  • 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, 8996
  • 8620, 8745, 8748, 8755, 8756, 8778, 8810, 8994
  • 8050, 8325, 8620, 8745, 8748, 8755, 8756, 8765, 8778, 8810, 8994, 8995, 8996
You can view the full recall details via the following link:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
Jan 09, 2010 | Graco Lajobi Kendal Convertible Crib
Dec 27, 2009 | Simplicity for Children Aspen 4-in-1...
Sep 18, 2009 | Simplicity Baby Gear
Sep 15, 2009 | Simplicity Baby Gear
Lost manual for simplicity crib model number 8755ht
Hi
I just found my manual simplicity 8755 ht.
If you still need one I could fax it or try and email.
Jeffwmeyer@gmail.com
Mar 22, 2009 | Simplicity for Children 8994W Crib
Simplicity # 8748AWT lost instructions, help!!
it has been recalled, google simplicity crib 8748AWT, I just returned mine to walmart
Jan 25, 2009 | Simplicity for Children Milan 4-In-1...
Looking for simplicity crib instructions (part # 8644C)
this crib got recalled make sure you call babies r us to look up or the recall list for cribs please.
Oct 11, 2008 | Simplicity for Children Columbus 4 in 1...
Toys Logo
166 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
