Question about Invacare Pronto M51 Power Wheelchair
Light blinking green fast - Invacare Pronto M51 Power Wheelchair
  • lennieg2000 Sep 07, 2010
    Which Light? Is it the wrench light at the bottom of the joystick or the battery level lights? If it is the wrench count the number of flashes there should be a slight pause between flashes.
  • lennieg2000 Sep 09, 2010
    Baze I'm gonna assume you are talking about the wrench light at the bottom of the joystick. Now it doeas blink fast but it does have a pause between flashes. Now you have to count the number of flashes between the pauses ie 4 flashes pause 4 flashes pause etc. Thos will give us the flash code and from that I can tell you what the problem might be Thanks
    Novelist:
    Champion:
  • 232 Answers
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
Blinking timer light Mitsubishi wd65735
Based on the service manual:
1)Fast Blink Green= Initialization (40 - 60 seconds) (AC Off)
2)Slow Blinking= Green Power On Timer is set.
www.aaatvservice.com
Aug 10, 2014 | Televison & Video
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
Energizer model chdc7 charger green lights flashing very fast
Single Blinking Light means it is charging, eventually the top green light will start blinking to show that it is half way charged. If both lights blink at the same time repeatedly this means there is something wrong and the charger is not charging the batteries.
Sep 24, 2012 | Cameras
When the computer is plugged there is a fast blinking green light and will not turn on
A fast blinking green light means the power supply is bad and will have to be replaced. Make sure you replace it with a least the same wattage supply that is in it now.
Hope this helps.
Feb 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Green blinking (bottom) light. No paper feed or test print can be performed
O'Neil MF8i Infrared Printer Green light blinking problem,
Solution: There are two types of green light blinking problem slow and fast blinking so in case of slow blinking you should change the IC-LT1776 part location number on the board U14 and if the light fast blinking then need to change the part number U20 on the board.
Note: U20 Can be replace with working one only if you buy new one that will not work because its programmed by the manufacturer and normally U20 become faulty and U14 & U20 location numbers are for the old version board. With the new version board the ICs will be the same but the location number will be different.
Sep 07, 2010 | O'Neil Printers O'NEIL MF8I PORTABLE DOT...
No power, fast blinking flashing green light where I plug power cord in.
Good day
Kindly provide the following for us to provide a direct and final solution to your problem
1. Does the blinking light changes from yellow to green or vice versa? 2. Is there a blinking red light? 3. How many blinks do you think it blinks?
Should you have any questions regarding the questions above, feel free to approach and ask us.
Good day and God Speed.
Jun 14, 2010 | Computers & Internet
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Invacare Pronto M51 Power Wheelchair Logo
162 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
