Question about General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane
Water leaking - purging out the weep hole on the side of the faucet.
3 Suggested Answers
SOURCE: GE smartwater R.O. system leaking out weep hole
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
Posted on Oct 02, 2009
SOURCE: GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
Undercounter r/o water filter vacuum
Water flowing past a hole (or connection) in a pipe will cause a vacuum at that connection. Is there water flowing anywhere else in the system?
Mar 24, 2014 | Plumbing
Try purging air from filter, read instructions to find purge valve, if none try running water and air should purge naturally
R/o faucet weep hole has a vacuum issue
Try installing a check valve, or back-flow preventer. Also try getting all the air out of filters, they may have a purge valve or small screw to remove air from system.
Mar 24, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Weep hole
THE WEEP HOLE IS THERE TO TELL YOU THE BEARING AND OR SEAL IS GOING BAD.NOT A GOOD IDEA TO PLUG IT.
Jan 03, 2014 | Cooling System for Kia Rio
Mintcraft kitchen faucet # 630-553 leaking from small hole in back of faucet
The hole is very small in the tail pipe and when you throw food, grease, it clogs this hole either partially or fully. When this happens then the water runs all over the sink through the weep hole. Which is the worst design I ever seen. By hand unscrew the black compression nut. Get a pipe cleaner or piece of wire, clean out the tube and especially the drain saddle. Reassemble and problem should be fixed.
http://www.ibathtile.com/bathrooms-kitchens/Hansgrohe.html
Sep 14, 2011 | Vacuums
Water leaking from front of oil pan
Very likely coming from the weep hole in the water pump, and dribbling down front of engine.
The weep hole is usually on the hidden side (back) of water punp and not easily seen. follow the trickle.
When water pump begins to leak like that, it means the bearing are wearing, and the seal is giving out as consequense. It will steadliy get worse. Verify the source of leak and replace the water pump if indicated..
Jul 12, 2011 | 1992 Jeep Cherokee Sport
There is a very slow leak only at the weep hole site under the faucet, not at the main faucet outlet
The hole is designed to let water out instead of going back into your wall. The spout needs to be taken off (unscrewed usually by hand) and tephlon tape needs to be put on the threads coming out of the wall. After this is done, screw the spout back on. Should be all set.
Dec 31, 2009 | Delta RP17453SS Standard Diverter Tub...
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Feb 13, 2009 | General Electric Profile Smartwater Ultra...
2000 Jeep Grand Cherokee Limited
No, what you're seeing is the weep hole leaking on the water pump. This is the warning sign that the water pump is worn out. Don't use any stop leak or anything to attempt to stop it. You'll be waisting your time. You'll have to replace water pump at this point.
Jun 13, 2008 | 2000 Jeep Cherokee
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
777 people viewed this question
Top General Electric Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
