Question about Kenmore 62622 Electric Dryer
Heating element stays on all the time - Kenmore 62622 Electric Dryer
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That sounds like a timer problem...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 | GE Dryers
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
Stovetop heating elements turn off and on intermittently. They don't stay on.
The heating elements on an electric stovetop are controlled be a control called a reohstat. The reohstat regulates the temperature to the elements and as such they do cycle on and off during use. If you turned the control to low and the element stayed on all the time it would get too hot and burn what you're cooking.
Feb 06, 2011 | Kitchen Ranges
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
Takes a long time for clothes to dry.
You have a bad element, these are fairly cheap and easy to replace.
Dec 27, 2008 | Frigidaire Dryers
Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Oct 29, 2007 | Dryers
Heating element
this could be a partial faulty heater element, a 2 heat element could only be working on 1 element, this can overload the other one causing it to keep switching on and off at the thermostat, sometimes this can be normal but saying as you think its not hot enough, check you have the settings correct on the heater options, i have seen stranger things happen test element contacts for both circuits unplug machine first
Sep 27, 2007 | Hotpoint TDL14 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 62622 Electric Dryer Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
