Question about Nikon COOLPIX L20 Digital Camera
Nikon Coolpix L20 won't turn on. When power button pressed, there's nothing, no sound, no lens movement, no LCD message, just nothing as if there are no batteries. Tried multiple pairs of fresh batteries.
  • 102366 Answers
SOURCE: lens error for nikon L20
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon-authorized service representative."
Posted on Dec 28, 2009
  • 102366 Answers
SOURCE: hi i have lens error with my nikon coolpix
Sadly, the camera needs service.
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: I have a Nikon Coolpix L20. And I keep getting the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 03, 2010
  • 102366 Answers
SOURCE: where can i download software for a nikon coolpix
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
There are also plenty of photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
You can download the current versions of Nikon software, including Nikon Transfer and Nikon ViewNX from http://support.nikontech.com/app/answers/detail/a_id/61 . Nikon Transfer is used to transfer pics from the camera to the computer, either through the USB link or via a card reader. Nikon ViewNX can be used to catalog your pictures.
Posted on Mar 13, 2010
SOURCE: how can i use my nikon l20 as webcam also
i plug in my camera to my computer and it wont turn on. when it does turn on my computer dosent recognize my camera. how do i fix this?
Posted on Jun 24, 2010
My nikon coolpix l20 wont power on
Pardon the dumb question, but are the batteries good and inserted properly?
Does the camera respond at all when you press the power button? Any beeps, flashing lights, messages on the screen, the lens trying to extend from the camera body? Anything?
Mar 07, 2013 | Nikon COOLPIX L20 Digital Camera
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
Aug 28, 2017 | Nikon COOLPIX L20 Digital Camera
How to delete pictures on my L20
For deleting pictures on your Nikon Coolpix L20 please follow the instructions below.
1. Highlight the picture you want to delete on the monitor.
2. Press the delete button ( button on right bottom of LCD monitor having a symbol of an open basket )
3. A window showing YES or NO for erasing the image is displayed on the monitor
4. Use the multi selector switch ( UP OR DOWN) to select YES
5. Press OK
This will delete the picture.To exit without deleting the picture choose NO and press OK.
Jun 19, 2011 | Nikon COOLPIX L20 Digital Camera
My Nikon Coolpix L20 digital camera won't turn on. When i hold down the power button, there's no sound or lens movement or message on the screen or anything. What do i do to turn it on? Help me please!
go check the placement of battery, see if polarity is properly follows.
if hardware issues, remove first the ssd card, then turn it on. see if this unit turns on.
let me know.
Feb 08, 2011 | Nikon COOLPIX L20 Digital Camera
My camera Coolpix L20 is no working anymore. When I turn it on, the screen become white, nothing appears. The buttons's sounds it is OK, but no images appears in the LCD screen.
slap it into the lateral face , force the lens while turn on the camera, pressing OK while turn on the camera, it is risky but if you dont want to go to a shop camera you have to take this risk
Nov 03, 2010 | Nikon COOLPIX L20 Digital Camera
Nikon coolpix l20. I cannot turn the camera on.
I HAVE THE SAME PROBLEM, DOES ANYBODY KNOW HOW TO SOLVE THIS
Mar 15, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
Camera will turn on and there is a clicking sound but the lens will not extend. lens error message
With new batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 13, 2009 | Nikon COOLPIX L20 Digital Camera
Dropped camera in sand
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 26, 2009 | Nikon COOLPIX L20 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
649 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
