Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave is beeping even though everything has been cancelled. We already tried unplugging to reset....still beeps.
  • GE Master
  • 9,086 Answers
Chances are you have a shorting membrane keypad. It's very common.
Ever had the F3 error?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Sep 08, 2010
My whilrpool stove goes in fse1 error mode and beeps constantly. even after i push cancel, it seems to reset then goes back to beeping after a few minutes without even being touched. I unplugged, reset and...
Hello jerseydev594,
You might want to visit the Product Owner Center on WhirlPool's website, which is: http://www.whirlpool.com/owner_center
My guess is that your WhirlPool stove might be malfunctioning so you might need a replacement unit if possible, Again, http://www.whirlpool.com/owner_center can help you.
Sincerely, oliver18754
Jul 08, 2011 | Microwave Ovens
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
The microwave is on lock and i do not know how to unlock it cause its making a beeping noise
If nothing else you can just pull the plug on it for a minute and plug it back in. You will have to reset the clock but that resets everything. Usually you can try pushing the cancel button a few times to get out of these but the plug does it every time.
Oct 10, 2010 | KitchenAid KHMS155L Microwave Oven
Lock function reset for model JMV8208BAS
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
appear in the display
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
140 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
