Question about Canon iP4700 InkJet Photo Printer
ERROR 6A80 IN PRINTER IP 4700 CANON, WHAT IS PROBLEM?
  • 32 Answers
SOURCE: error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Posted on May 28, 2009
pinic
SOURCE: I have a Canon, Pixma
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
Greetings Pieter.
Posted on Sep 03, 2009
  • 1335 Answers
SOURCE: Is there a fix for error 6A80 for a Canon mx700
You can try a few things:
RESET the printer:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Check for paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
(A) When printing from the Rear Tray
(B) When printing from the Front Tray
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
i_note.gif Note
bullet_s.gif When reloading the paper in the machine, confirm that you are using the correct paper and are loading it into the machine correctly.
bullet_s.gif A5-sized paper are suited to print documents consisting mainly of text. We do not recommend using such paper to print documents with photos or graphics, since the printout may curl and cause paper exit jams.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, you should take the printer to a service shop since the printer will have to be disassembled to remove the torn paper.
Posted on Oct 16, 2009
rulds2008
  • 3866 Answers
SOURCE: please help, my printer canon ip 3300 has message B200
Okay from canon on this one this is a Hardware Failure there is nothing more that can be done unless you have $50 bucks for the main singal proccesor board that sends the signal from the printer to the computer and vice versa. So a unwavering support indeed I gave but the fix can be expensive would recommend just recycle it and buy a new printer for under $50 buck you can get twice the quality from lexmark!! Thanks and this tech deserves his 4 thumbs up and a pat on the back don't you think? Do it today we earn your respect as techs by your ratings and feedback thanks and May god bless your family during this holiday season!!
Posted on Nov 24, 2009
  • 8 Answers
SOURCE: Error Code 6A80 on the Canon MX700
Supply Guy,
Here is the solution.
I am going to describe 4 buttons on your printer. Then, I will tell you what to do with these buttons to resolve this error.
1. Look for the Black & White selection button (large white button w/ black diamond on it).
2. Look for small pink button (bottom left corner of your printer control panel).
3. Look for the OK button (big button in middle).
4. Look for the On/Off button (top left).
OK - here we go. With the printer turned off, do this:
1. Using four fingers, one on each of the four buttons, press them all and hold them down for 10 seconds.
2. Release the On/Off button - but keep holding the other 3.
3. After a few more seconds the printer will turn on. When it does this, you can release the other three buttons.
So, to summarize, you press all 4 buttons for 10 seconds, release the power button and wait for the printer to turn on. After it is on, let go the other 3.
Your error message should go away. If you don't hold the buttons all down simultaneously, the printer could go into Fax mode; just turn it off and try again.
Posted on Dec 29, 2009
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
Error number 6A80 for pixma canon 4700 how to fix it?
  1. Start with this process with printer off
  2. Press and hold resume Button (triangle in the circle) and press power button. the green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Aug 27, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error 5100
HI:
ABAUT ERROR 5B00 4700
CAN YOU HGELP ME
WE CANOT BUY THIS SOFT WEAR
I DONT HAVE MASTER CARD OR ...ACOUNT
BECAUS I FROM IRAN
i need free link for this soft wear .
plz help .
"Service Mode Tool Version 1.050"
this softwear resset counter for printers ip 4700 models AND ERROR 5B00
my id: ali_myone@yahoo.com
privait email: yousefi @ emc.ir
plz send links or rar fils to my email or yahoo id
have good time
tanx for all
Mar 28, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon iP4700 InkJet Photo Printer Logo
900 people viewed this question
old marine
old marine
