Question about Maytag Neptune MAH55FL Front Load Washer
Got this washer yrs ago..never used. Just hooked it up & want to run a bleach cycle to clean out so I can wash clothes after. What do I do?
  • 343 Answers
A simple way to put a cleaning cycle through the machine is to fill to the highest capacity with warm to hot water and add a cup or two of bleach. Any bleach is ok, but chlorine bleach if your plumbing type allows it is stronger. TIP.....Do NOT mix any wash powder or detergent with the bleach (Check Directions)
Let the machine do it's longest wash, with soak, if it's part of the programme, and after a normal rinse you should be good to go!
Good luck....Nomess
Posted on Sep 07, 2010
How do i remove black mold on gasket
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Tip
Eliminate washer Odor
To clean washer add 1 cup of bleach while washer is being filled with hot water and run entire small cycle. DO NOT add clothes. This will help to eliminate odors and any stuck on dirt/ grime on the sides of the drum before washing clothes. I'm not an expert, just an experienced clothes washer for over 30 yrs. ,
on Oct 19, 2013 | Washing Machines
I have some sort of wet guck in the gasket. It took me forever to find where the smell was coming from. I have to clean it out every time I use the washer. Please help.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back for more information
Daniel
Nov 26, 2010 | LG WM0642H Front Load
The water smells bad as if it is not draining correctly. Is there a water filter that needs to be replaced? How do I clean out this washer to get it smelling nice?
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps.. Please post back if you need mor information.
Daniel
Nov 26, 2010 | Bosch WFMC 3200 Front Load Washer
Mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG tromm mold smell.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps...
Daniel
Sep 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My clothes have a musty smell after being washed
run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag Neptune MAH55FL Front Load Washer Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
