Question about Samsung TX-R3079 Television
Samsung txr3079whx/xaa, watching tv, then shuts off on own. no popping sound, just shuts off. have to wait 5-10 minutes then can turn back on.
NECESITO SABER COMO CONSEGUIR ESTA PIEZA LA NUMERACION ES SLA1004
Posted on Nov 30, 2010
My samsung tv LNT4669FX/XAA screen is blank but the tv and backlight work. how do i fix the tv?
It sounds like the screen may have failed, that means a new TV will be needed.
Feb 24, 2017 | Samsung Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 31, 2017 | Televison & Video
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
I have a samsung TXR3079WHX/XAA tv, it is dead, no power no lights, nothing happens when u press the power button
In that case you had a major failure in the power source. The tv must be tested by a repairman or someone with electronics experience.
Aug 27, 2010 | Televison & Video
Problems with Samsung TV
try to soldering back your tv ic board first
Jun 25, 2008 | Televison & Video
Samsung HCM4215W,shuts off.
Sounds like a short in the power wire, it takes about 10 to 15 minutes to warm up then shorts out and when it cools down you can watch for 10 to 15 more minutes before it shuts off again, you need to take it in and have the powercord replaced because this is very hard to do from home and one mistake can make the whole tv not work.
Feb 27, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung TX-R3079 Television Logo
471 people viewed this question
Henry  Thomas
Henry Thomas
