Question about Konica Minolta magicolor 2300DL Laser Printer
Multi color edge
When printing, I have multi color toner on the edge nearest door, only 1/16 to 1/8. I can see it on the imaging roller and last roller b4 paper comes out but can't see where its comming from
    Champion:
  • 214 Answers
Do you use refilled toners, if yes, then probably check toners, also check pc drum and transfer belt and clean laser glass
Posted on Jul 02, 2008
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Samsung CLP-315W color problem. The toners are all about 50% but the pictures are coming out red and very little yellow. I have cleaned the inside and emptied the extra toner.
Here's something you can try. There was a model of Samsung color laser that had an issue with the cleaning blades in the toner cartridge or toner transfer roller assemblies.
There are two types. I believe yours uses a "classic" toner cartridge (rectangular with a toner transfer roller on one side and a metal plate almost touching the toner transfer roller).
The metal plate can be removed and the edges cleaned. When you remove it, inspect the edges. One edge is used to clean the excess toner from the roller as it turns. Very gently clean the edges with a soft cloth and some windex or alcohol. Reassemble and test.
The other type uses round drum shaped toner cartridges. These printers have a toner transfer assembly for each color inside the printer on the main image transfer unit. These toner transfer assemblies will also have metal plates on them which can be cleaned. They must first be removed from the toner transfer assembly, you may need a jewelers screwdriver to remove them.
Be careful, the cleaning edges of these metal plates can be very sharp.
Oct 07, 2010 | Samsung CLP-315W Laser Color Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
New Black Toner Cartrige Poor print quality
I have solved this problem. You will have to remove the imaging unit from the printer. Once out, remove the two screws that secures the drum to the imaging color rollers. This is the tricky part...carefully pry the two tabs in the back of the drum bracket to separate the whole unit. Once out, you will see all four color rollers. Carefully remove each one in order...black will be the last. Once the black roller and toner container is out, proceed to remove the 4 phillip screws that hold the metal distribution plate. The problem is that the heat will bond a small amount of toner on to this plate and keep it from distributing toner properly. Carefully scrape the inside of this thin plate..you will feel a rough edge. Scrape until smooth and reinstall the plate back into the toner container. Reinstall everything back and VOILA!
Have fun fixing this printer!
Jul 14, 2009 | Samsung CLP 300 Laser Printer
White stripe in print-outs
This is a common problem with this printer. Each toner color has it's own roller. The tin blade on the inside edge of the roler gets plasticy buildup and needs to be cleaned.
Pull out the entire toner roller assembly for the color that is problmatic. Unscrew the tin blade from the roller assembly. Clean the inside edge of this blade (the part that scrapes on the roller) completely. NOTE: After cleaning mine with toilet paper & water I ran my fingernail along the edge to find that the waxy buildup was still there. I gently took my fingernail and scraped at it until it felt smooth -- no burrs.
NOTE: The edge of this blade is very sharp! Be careful. Don't run your finger along the edge.
Reinsall the tin plate maing sure that the foam sweeps (on the right and left of the blade) are not stuck under the tin blade. (If you do, it will dump large amounts of toner on your pages. Very messy).
Give her a whirl.
Apr 05, 2009 | Samsung CLP 300 Laser Printer
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Copy Problem
did you check the toner? sounds like the toner is out, also check the side door there should be a black roller there is it O.K ?
Dec 24, 2007 | Canon PC-980 Color Copier
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
