Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I have a Maytag MFI2568AES french door refrigerator. My problem is that the top doors don't seal very well, especially the right one. Closing the left door inevitably causes the right door to slightly pop open. What parts do I need to change to cause the doors to seal reliably again? Thanks, Marc
  • 3,083 Answers
Most likely, the doors just need proper adjustment. One VERY important factor is that the unit be LEVEL!
Read my answer to another person who had door problems with a French Door GE, and the ehow link explains adjustment procedure.
Your doors will be similar, but I could not find exact links relevant to your model.
http://www.fixya.com/support/t5880974-ge_profile_french_door
The lady messaged me back later that she had fixed her problem by leveling the unit. I had read it on some sites, but paid little heed to it, but it is very important.
So make sure your unit is level front to back, and side to side. If that doesn't fix it, start investigating the door hinges- there should be adjustments similar to the G.E.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 07, 2010
How do you change the water filter on Maytag MF12568AES?
Check top right inside of frig. Filer is inside the housing; open door turn filter counter-clockwise, the housing should allow you to lower filter to change it out. Place new filter, turn clockwise, push back into place and close door.
Apr 19, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Door has lost suction when closing.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Mar 27, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Were is the filter located on this model of frige we just bought it of a firend and he has lost the manual for it and we would like to replace the filter.
On my Maytag bottom freezer French door model the filter is inside, at top right tubular form on "ceiling" with a tab on front says "push". Cartridge filter inside.
Feb 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker wont make ice. Any ideas?
tempt in freezer not cold enough or water inlet is frozen . defrost it with a turkey baster and hot water .. this may be caused by the water valve not closing complety and if so replace the water valve .. mm
Aug 03, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
81 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
