Question about Sport & Outdoor - Others
Manual for 1984 larson citation 5500 boat - Sport & Outdoor - Others
Witch model of boat do i have with ser no LAR75995H405
Sounds like a 2005 Larson. All boat manufacturers go by the last two digits to identify the year. The 180 or 186 is the model number which normally corresponds to the boat length: 186 meaning 18'6" and 180 meaning 18 feet.
Dec 23, 2014 | Boating
Have a Larson boat need to know the year of the
The serial number is so short it makes me think it's a 1958 model but newer models with 9 digits or more use the last two numbers as the year model which would make it a 1980. You can verify this by either going to NADA.com and looking at the different model names and numbers or just calling your state's boater registration department and asking them.
Sep 28, 2014 | Boating
Where are the fuses located on a 1998 Larson SEI 186
some boats put them under the dash some inside the cabin if so equiped .
Jul 13, 2014 | Boating
I have a boat its a larson lazor its got the 5.7 350 with the cobra outdrive i took it out for the first time and it overheated what could cause this?
probably the cooling system. take a look at the radiator, water pump and all hoses. you might want to do a pressure test as well if you notice that there is not enough coolant in the system.
May 02, 2014 | Boating
My 1984 chevy citation 2i died in the middle of the road...4 cylinder model.... its not spraying fuel and not getting spark the fuel filter is good fuel is getting to the injector but not spraying..... i...
Are you getting power to the coil ?
It could be the stator-pickup in the distributor or a lack of voltage to the ignition system.
Is the check engine light on when you turn the key on ?
Aug 01, 2012 | 1984 Chevrolet Citation
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
Needed owners manual for a 1984 36'Citation
you should have a battery in the forward compartment right side there should be a light switch low on either the dining bar or, wall assuming that your unit has electric slideouts.
Aug 29, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Sport & Outdoor - Others Logo
219 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
