Question about Lowrance LMS-527C DF iGPS GPS Receiver
Does a lowrance 527 igps have an internal battery
How can a lowrance 5300 globalmap iGPS be used as a fishfinder.
Sadly, the 5300 does not have fishfinder/depth capability.
If you require it, the link below is for the owners manual for your unit.
Sorry I couldn't have given you happier news.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5300ciGPS_0152-191_120506.pdf
Feb 24, 2015 | Lowrance Globalmap 5300c Igps 5" Screen...
Is there an external antennae for the lms 527 combo available
  • No it does not. Lawrance often makes either external or internal GPS units. This is an internal antenna unit only model. Hope this helps.
Regards, Tony
Jun 05, 2011 | Lowrance LMS-527C DF iGPS GPS Receiver
My Eagle 642C iGPS does not work with Lakemaster chip
If you do not have the most current software upgrade, that may be the problem. Go to www.eaglenav.com. If a more current software is available, download per their instructions. Worth a try. That unit should display LakeMaster digital chars.
Apr 04, 2010 | Eagle Industries FishElite 642C iGPS GPS...
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Gps wont pick up satilites
Make sure all the connections at the back of the unit are tight. If it still doesn't respond try a new puck.
Apr 15, 2009 | Lowrance Globalmap 5300c Igps 5" Screen...
NEED TO TALK TO SOMEBODY
Hello al56-mueller, I searched the same areas I'm sure you have and the only one thats verbal is a dealer. Merry Christmas.
Dec 02, 2008 | Lowrance Boating
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LMS-527C DF iGPS GPS Receiver Logo
62 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
