Question about Vacuums
Noisey hoover my hoover has started screaming it still succks well and can be used as normal except it is almost deffening
  • snez May 13, 2008
    i've taken it apart and cant see anything visible the belt seems fine it does sound like its going to take off some people have suggested it could be a broken fan but i cant see one???
    President:
  • 1,673 Answers
Wish you have posted the model number, but the fan on alot of the Hoovers are on the end of the motor, opposite the motor shaft. You will have to pull the motor out to see the fan, if broken, replace it by taking the 4 screws out and removing the fan housing, There will either ne a bolt to remove, or the fan will unscrew by turning clock wise. Sometimes they are tough to get off.
Posted on May 13, 2008
My dyson dc24 brush bar will not turn and there is a very loud screaming noise coming from the Hoover
Something has jammed the brush roller and the screaming sound is the motor shaft trying to move the stuck drive belt. The vacuum will have to be disassembled to find and remove the jamming material.
Oct 23, 2016 | Dyson Vacuums
My Hoover 2X PetPlus Pet Stain & Odor Remover (64 oz) turned my off white carpet rusty orange! The liquid itself was orange brown. Is this the normal color?
I don't believe this is normal. I would contact the company. I would use 1 part white vinegar to 2 parts water and put it in a spray bottle. Use that to clean pet stains.
Sep 19, 2016 | Hoover Vacuums
The make of our hoover is solec ci 1600w it has lossed suction, has got noisey, and cuts out when it gets hot
Here is a link to the hoover site where the manuals are. My guess is that either your filter is dirty or you have an obstruction in your hose or head and it needs cleared which the manual should guide you to resolve. I was unable to find the model you have by your description but you should be able to as the search function will guide you to enter the necessary information to get you where you need to be. Best of luck
Product Manual Search
Aug 28, 2016 | Hoover Vacuums
Where can i order a hoover bag and filter for a nilfisk gsd 80 hoover and how much will these items cost me
First try online using Craiglist, Ebay, or look for local store near you. If you want to save really good. Some goodwill, Salvation Army, Value Village Stores do have new or second hand vacuum bags. Just write what you need, the Model Number, or the Type A or B Vacuum bags. Usually Hoover bags are popular. Except some new ones and also High End Vacuum like Kirby, and Vacuum from TV Informercials.
Sep 07, 2010 | Vacuums
Just bought this Hoover Fusion vaccum used, cleaned it up, checked belt and filter, turned it on and is extremely loud, almost like a scream. Any idea what could be causing this and how to fix?
Loud noises from this model are caused by dirt build up on the suction fan mounted directly to the motor. Under the dirt cup there is a filter screen that should have a foam filter insert, when not used or cleaned properly allows dirt to get into the motor. Cleaning is the best option. Although if you are inclined, you can take it apart or take it to your local deaLer.
May 01, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Started making a loud noise
Wish you had included your model number, could have a clog in the hose or inlet by the brush roll. Sometimes a bad belt will be noisey as well as a bad brush roll. The motor fan may causing the noise, or motor bearings.
Aug 31, 2008 | Hoover Vacuums
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
had my steamvac spinscrub for 3 days now. it will not **** up why?
Jan 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
High rpm
These machines are noisy to begin with, but will become worse if anything is allowed to enter the fan area of the motor. I have seen debris clog the front fan and put the motor out of balance so it will really scream when it runs. This work is best left to a competent professional
Jan 11, 2008 | Hoover Portapower C2094 Bagged Canister...
Vacuums Logo
115 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
