Question about Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
I have good water pressure going into the flexible lines of the Grohe Kitchen faucet but very little pressure coming out of the tap. I have taken the nozzle assembly apart several times but there are no obstructions. Is there possibly an adjustment or filter inside the control arm at the base of the goose neck?
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Install a new cartridge assembly. Contact Grohe and ask them for free replacement parts.
Posted on Sep 08, 2010
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
http://www.doityourself.com/forum/plumbing-piping/310875-low-water-pressure-new-kitchen-faucet.html#b
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
How do I replace flexible pressure hose in Grohe Eurostyle bathroom mixer tap. I can not just unscrew it at the bottom.
STOP and look it over really well . some of the newer ones are just a slip joint coupling others simply unscrew from below
Feb 07, 2015 | Grohe Plumbing
Low water pressure in my grohe bridgeford kitchen faucet what could be the problem
The first thing to check is the areator at the end of the spout...
They often plug with dirt and drop the water pressure...
Take that off and check out the water with it off...
Then if it is still low then it is dirt trapped internally in the faucet...
heatman101
Sep 26, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Change grohe faucet washer
Hi, Ensure that all water is switched off from the mains incoming tap, and hot water turn off tap under your boiler if that's the system you have.
Next open both levers of tap to ensure no water coming out, then remove heads with adjustable spanner. (Anti clockwise). Take to nearest plumbers merchant and they will supply new washers. It is a good idea before putting heads back in! get some de-scale liquid and spray them until lime-scale removed.
Screw heads back in turn off both taps and re-instate water supply. Then open both taps to clear any air in system.
And that's it.
If you find the heads are in bad order then you can buy replacments cheap enough, Just ask your merchants advice.
Hope this helps Thanks Paul.
Aug 31, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Lack of Water Pressure
If you have the spray head type, I had the same problem...called Grohe. They said to remover the pressure regulator. Take off the spray head, and just inside the end where the water comes in, you will see a white plastice thingy. Remove it. They said you can do it with needle nose pliers, but I had to pry it our with a tiny screwdriver. It came out in pieces, but once out, the water pressure is GREAT!
Mar 07, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I have a Grohe Ladylux Plus and the water pressure was good till about 6 weeks ago. Now I have very low flow in kitchen. What do I do?
If it is just this faucet and no others then it is likely the filter screen in the tap head is clogged.
Remove the cover from under the tap head. Pries off from the tap head directly where the water comes out.
There is a metal mesh screen there. It will be full of white chalky deposits from minerals in the water supply. Clear that out and you will be good to go.
You will also want to clear the holes for the spray pattern. The same deposits will be there.
Good luck.
If this helped give you some direction please rate the answer for me.
Thanks.
Jan 28, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
758 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
