Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
How I clean the machine?
The brushes are full of stuff and the surrounding area is full also, this carpet is low quality and lots of carpets hair got out, how can I clean it?
  • holky May 13, 2008
    Thanks, that helps. I borrowed it from my friend and I don't want to mess it up. Again Thank you.
    President:
  • 1,673 Answers
Take the front piece off, there is one screw in the center of it, on the top, Then remove the 2 clear covers, one on each side. then you can get in there to clean the brushes, also can take them off if you want to.
Posted on May 13, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
How do I clean the brush area after using my Pro Heat?
The brush or brushes (depending on your model) can be removed if needed. Routine cleaning should just require removing hair and debris from the brushes and wiping the area around the brushes.
There should actually be very little hair or debris around the brush roll if the carpets are thoroughly vacuumed by a properly working vacuum cleaner before being cleaned.
Jan 22, 2017 | Vacuums
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Doesn't pick up hair from the carpet
the beater bar bearings are likely clogged with hair or carpet fuzz... without the belt the beater bar/brush shouuld rotate smoothly .. if it is hard to turn then remove it and unwind all the stuff wrapped around its bearings (at each end) ... make note of how it was mounted so you can replace it the same way ... sometimes it takes a little fiddling to get all the stuff out thats wrapped around the ends .. also remove all the stuff captured by the brushes .. a pocket knife helps a lot to do that ... once its all cleaned outl, make sure the end bearings work freely .. reassemble and it should work great ... if you have trouble doing that then you can look for a vacuum cleaner repair place near you ... its too bad not every area has such nice people as the one near here ..
May 22, 2010 | Dirt Devil M084000 RoomMate Upright Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
Carpet cleaning brush noise. When put in carpet cleaning mode, a loud noise comes from the brush bar area. We see no visible obstructions and have cleared threads and hair.
It's likely that one of the brush roll bearings has worn out. This is not uncommon. I think you'll find that you have to replace both the brush roll and the sole plate at the same time. Dyson sell them together as a kit.
Dec 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell Pet Hair Eraser Vacuum marking carpet
the brush is always turning on the machine even when your using the tools. try not to set it down on thick carpet , or if you can set it on the linoleum.
Sep 16, 2009 | Bissell Upright Vacuum - The Pet Hair...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
