FixYa.com
Tags:
Panasonic CT-36D32 36
Green coulour?
posted by drrutled on May 13, 2008
When you first turn on the tv the screen shows up green over the picture, then if you hit the side of the tv it will goto regular picture, but then it will periodically go green agian by itself, and agian, if you hit it, it goes away. If the picture is fine and you hit it you can get it to flicker green. What is causing this and can i fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 13, 2008
Helpful (85)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 590 votes
This is a classic indication of poor solder connections inside the set. If you are comfortable with electronics and can solder, open up the unit and resolder any connections that appear grainy or have rings. That should resolve the problem.
Dan
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
Panasonic CT-36D32 36" TV
TV goes on and off...
The panasonic tv just started... Answer This...
Please Help !!!!!!!!!!!!!!!!!!!
I have a Panasonic CT-32d32... Answer This...
27" Panasonic TV 1993...
I have lost picture ,Black... Answer This...
HELPPPPPPPPPPPPPPPP!
My Panasonic CT-32d-32f tv has... Answer This...
3D will not turn off
Have Panasonic TAU 34"... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
