Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
Motherboard wahla when the motherboard is powered the onboard green light comes on but no beep is heard or any display on the monitoring screen is seen. what do i do?
  • axle_584 Jul 28, 2008
    Genius:
  • 2,785 Answers
Resit the ram,try with another power supply,if problem is not solved then your display adapter is bad, send the board for repair
Posted on May 17, 2008
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
No signal to monitor.all connections and videocard seems ok fans work , What can be the problem? send a Trouble Shooting chart please
Okay here are the steps.
1. Turn off computer and restart it with tapping F2, the BIOS screen should come up. 2. If that does not then your computer is not clearing the POST or Video part that comes right after post. 3. Take the video card out and connect the monitor to the On-Board card on your motherboard. 4. If that works then there might be a problem with your video card. 5. If that does not then there is some more troubleshooting to do, try take the memory cards out and see if the motherboard beeps. This is to ensure that it is working fine or not. Put them back in and then try to turn on the computer.
Reply if need more help.
Thanks. If this was helpful, then kindly rate me.
Nov 01, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Green light is blinkeringon at the right side of the panel and there is no sign of activity on the screen. What can I do about it?
Try it on another PC to see if it stll has the same problem then open it up to check the power supply section, look for bad caps with bulging top, look for burnt marks on the PCB. Post back what you see inside so we can guide you further. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Neovo E-19A 19" LCD Monitor
Motherboard power is on but cannot display screen, the monitor is black or no screen.
your problem could be almost any of your hardware components
the best way to detirmine wich one/how to fix it is with a process of illimination. You should do this by switching your hardware components with known good ones.
being a display problem the order i would test with is this.
  1. disconect everything but the screen
  2. swap screen for a known good one
  3. disconect graphics card and try the onboard (if no onboard try another gc)
  4. test psu (power supply unit) this can be done with either a psu tester, multimitre or try with another psu
  5. try removing all your RAM, when you boot if your system beeps a couple of times you know that your motherboardand cpu are good. if it doesnt beep it is probably your motherboard or cpu.
Oct 14, 2009 | ASUS P4P800-MX Motherboard
No beep and No display on my monitor.
Did you swap RAM and CMOS from other PC? Try to swap the Power Supply, and the motherboard as well, make sure that these 5 parts are in good condition, 1. motherboard 2. powersupply 3. memory(ram) 4.Display adapters/onboard VGA 5. Monitor
Jul 06, 2009 | Computers & Internet
Giving green light and there is no display
disconnect the video cable that coonnects the motherboard and monitor...now switch on the monitor ..now a screen saver like video will come on monitor that says to connect the cable this means your motherboard has a prblem call the service center.. if not and still the monitor is on green light it means your display driver in your monitor would have got fried and your motherboard has no problem...
Apr 28, 2009 | Dell OptiPlex GX270 PC Desktop
Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!---
First thing I would do is try the monitor on another system to see if it's in the monitor or computer. Next would be to fire it up and see if you hear a beep from the motherboard. Most consumer pc's will come with a small speaker that sounds on startup. If you don't hear this beep it could be indicitave of a fried motherboard.
But it sounds to me like your video card or onboard video was messed up when the power supply conked out. If it's onboard video you may be able to switch to a video card. If it's a video card you may need to replace it.
Also check to make sure there are no loose wires, that your video card is seated firmly, and that your connectors are all snug. If none of this works then you're most likely looking at a motherboard replacement.
Apr 19, 2009 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
No output
if you are using pci or pci-e the motherboard maybe bad on the driver slots,if using the onboard system on the motherboard it is out and needs replaced. lala linda
May 31, 2008 | Biostar P4M80-M4 Motherboard
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
if you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Nov 27, 2007 | HP (5064-6630) Motherboard
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
