Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Red alignment is off and won't fix it's self - Hitachi 51F500 51" Rear Projection HDTV-Ready Television
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
You will need to replace the convergence chips--should be STK-392-150 in this model and set uses two of them. This can be a do it yourself repair and parts cost on EBAY will be well under 25 dollars. If this told you something you did not know, rate this solution as very helpful as I do this here for free. If you need instructions comment here and I will assist you. SD TECH
Posted on Sep 07, 2010
Oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Jun 09, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have a samsung 47 inch rear projection w/self focus there is a continuos blue shadow around images is there a quick fix
The blue is caused by the RGB gun alignment. Green is a fixed gun and Red and Blue are adjustable. In my Mitsubishi, the guns are motorized and can initially be adjusted (course) with the remote. There are more detailed adjustments that can be made if you purchase the service manual. I paid approx $19.00 on line 3 years ago and it is a complete manual. Unfortunetly I don't remember the site. To do a complete alignment, there are steps to take: starting with entering a code using the remote to enter the setup. To make a long story short, I had my tv aligned 3 or 4 times over 5 years under the extended warranty. After watching the tech, who was good, but under time constraints, it was clear that most anyone could do it if they could read and follow instructions.
Mar 05, 2010 | Samsung Televison & Video
Red alignment wont adjust
Go to www.tvrepairkits.com to get the right IC'S. the pico fuses are the F9A05 and F9A04.
There is a small tag inside the cabinet walls that show where these fuses are. You get a complete kit of picos, chips, resistors and pictorial instructions at the moment he best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees!
The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S.
The kit has full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases.
Jul 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
When tring to use the red convergence it seems to be twisting.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Mar 07, 2009 | Sony KP-61XBR48 61" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
309 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
