Question about Gateway GX7018E PC Desktop
PC wont turn on, fan rotates and stops - Gateway GX7018E PC Desktop
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
16 Inch Stand Fan with Remote Control (SD10-2) W wont stop roating
Hi Kayla...I have a granddaughter (whom I adore) named Kayla...:). I'm not sure if you found your problem yet, but it sounds like it has something to do with your remote control. If you give me some more information, I might be able to help you better. However, if you're able to turn the fan on and off without the remote control - does that solve your problem. Otherwise, read in your manual (if you got one, or were given this) to see if they have a troubleshooting guide. At least its rotating, cause I usually hear about them when they stop rotating...:) Best of luck, and I hope you found your solution already - otherwise, I'll be more than willing to help you through the process. Take care...Jim
Jun 01, 2014 | Dryers
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
Ihave a laptop acer aspire4520 the problem is it swithes on no display the cpu fan rotates for few seconds and stops what could be the problem
Try to change the RAM sometime it happens because of the RAM's. Or make sure that it is not overheating thats a cause too.
May 12, 2010 | Acer Aspire 4520 Notebook PC
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
K8mc51g motherboard wont turn on i shut it down and now it wont power on i tried reset jumpers and removing the battery for 30 sec and taking away all power for 24 hours
If after pressing power button the fan rotates ...then the BIOS might have been corrupt ...and if the fan dont rotate then the SMPS might have fault
Oct 21, 2009 | E-Machines eMachines Desktop PC
Cant turn on
Hi
U check whether power supply coming from the terminal or not.. if its coming then u check whether SMPS fan rotating or not.. If its not rotating means u have to change ur SMPS unit.. If that also rotating means u wont do anything.. Because next steps are complicated and risky.. Check whether the system under warranty or not.. If its warranty means u ask help from the warranty providers..
Oct 19, 2007 | Lenovo ThinkPad R51
Gateway GX7018E PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
