Question about Toshiba Satellite P105-S9722 Notebook
Toshiba Laptop wont work unless plugged in, i recently bought a new battery think that the battery was the problem and still it doesnt work unless its plugged in. please help me!
  • Anonymous Mar 23, 2014
    I recently got a new Toshiba laptop and the problem i keep having is it plays some videos online perfect but then with most others it
    just loads 3 mins then stops for no reason and wont load any further unless i reload the page or move it forward past the load stop point
    i also have a Sony laptop that loads these videos perfect with same internet so its not connection speed and its random, it might load 5 mins then
    next time just 2 mins. any help will be much appreciated.
  • 38 Answers
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
Posted on May 13, 2008
My toshiba click mini wont charge
If you are using the correct charger and it isn't charging, look at the port for any visual damage and make sure the charger is fully plugged into the laptop (may sound basic but best to cover everything)
You may also want to try plugging it in to different plugs.
If it still isn't charging you may want to considering removing the battery from the laptop and then plugging it back in and trying again, you may also have to purchase another battery if yours is faulty, if you bought it recently brand new then you may be able to get this via the warranty from where you purchased it from.
If you bought it second hand then contact the seller or merchant and request a replacement.
Nov 20, 2016 | Toshiba Computers & Internet
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My computer was working fine, but I lost my charger. I bought a universal charger and used it for some time. One day I plugged the computer in and the light on universal charger lit up until I plugged it...
I think that your battery is soooo flat it may be no good, take battery out, THEN connect the Correct adapter, and see if that works, if it does, then ya do need a new Batt, or perhaps a good long10-12 hour charge first, with NO use at all during that period.
Jan 26, 2010 | Toshiba Satellite M45X-S331 Notebook
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dec 27, 2009 | Acer Aspire One PC Notebook
My power socket in my computer doesent work i have bought new chargers and still can get it to come on
if you just plugged in a new charger you should be able to power it on even if your battery is dead. laptops can be powered on even without its batteries as long as the chargers are connected to the laptop. i think you have to bring your laptop for servicing.
Nov 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Jul 12, 2008 | ASUS Computers & Internet
Toshiba Satellite P105-S9722 Notebook Logo
591 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
