Question about Dryers
I have a Whirlpool Duet dryer that displays an E1 code occasionally. When this happens, the dryer shuts off and the code flashes. What could the problem be?
  • 10,319 Answers
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Posted on Sep 07, 2010
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 25, 2010 | Kenmore HE5
The dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer runs and heats well for 4-5 minutes then shuts off. it has a light that flashes E1. what is the problem??
E1 THERMISTOR OPEN "E1" flashes if the thermistor is open.
Check your wire connections on your thermistor and your control board. If they (connections) are good you should replace your thermistor. If you would like more detailed instructions in performing the "THERMISTOR TEST" post back here and I will find you a manual or find a way to scan you mine. Or, you can merely remove the top of your dryer and inside you will find the TECH SHEET giving you detailed instructions on this test and many more.
Cheers
Dave
Jun 07, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
150 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
