Question about Garden
Mower starts and runs fine. Engine does not cut out, nor does the engine surge. After mowing for 5 minutes or so the when I turn a corner the power seems to fade. The throttle can be fully depressed, but the mower just slows to a crawl. I have changed the air filter cover. I do not believe that the fuel filter is clogged because the engine continues to run fine even with the loss of forward motion. Any suggestions?
  • dlpowell Sep 07, 2010
    rpm stays the same. No change in engine revs, only in mower speed - it drops way off.
    Think a belt problem?
    Thanks for your help?
    Genius:
  • 1,400 Answers
Hello
Have a look at the float in the carburetor.Sounds like its sticking or gummed up.
Clean it out with gumout carb cleaner.
Posted on Sep 08, 2010
  • mpcheesman1
    mpcheesman1 Sep 08, 2010
    Ok
    I misunderstood,have a look at the drive belt for the rear wheels.Check the mower deck belt also.
  • 2,299 Answers
I would say that it is a belt if the power only seems to fade when you are turning a corner. Does the engine rpm stay the same? Or is it going way down, back to an idle?
Posted on Sep 07, 2010
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
******* mower cutting deck restart failure
Your switch may be bad or wire come off.
Jun 08, 2013 | Garden
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Engine cutting off
Depends on how it cuts off. If it gradually slows down over a few minutes or surges, it's likely the carburetor needs to be cleaned and rebuilt. But if it's an immediate cut off, it's likely to be a safety switch such as the one that shuts down the engine when you get off the seat if the mower is running. Sometimes this happens frequently to a light person who bounces on the seat when mowing.
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
