Question about Dell Latitude D800 Notebook
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
  • 388 Answers
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Posted on Sep 07, 2010
Dell motherboard not coming on
For latitude there's not much to do. check the power adaptor/connecting pin --- if any problem. If not than u need to replace the board.
May 02, 2014 | Dell Latitude D800 Notebook
Dell latitude d800 not switching on ?
I may have addressed this question earlier. If your Dell shows absolutely no sign of life... no LEDs, no nothing and you know for certain the battery and/or power adapter is good then...
If you have access to a docking station (ANY Dell dock that will mate with the bottom connector on your D800), put the D800 in the dock and use the power button on the docking station.
If the laptop powers up, you may have a simply problem with the laptop "Press to turn on" button.
ABOVE THE LAPTOP KEYBOARD...
Use a small flat screwdriver blade to remove the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys). Locate the cover's flat ribbon cable connector above the Page Up key. Pull off and carefully reinstall. Try the power button now. If it works, put everything back together. Otherwise seek profession help.
I need to unlock a bois pass word for dell latitude D800
The best way to unloc a BIOS password is to reset by removing the CMOS battery and while the mains is removed press the power button a few times and leave for about 30 seconds. Refit the battery and power up. Password should be removed.
Apr 12, 2013 | Dell Latitude D800 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
Cpu upgrade latitude d800
what do the Lock Lights indicate (Flashing , ON, ON perchance) it appears that the CPU is either not compatible or bad. Have you tried the original porcessor?
Jan 29, 2009 | Dell Latitude D800 Notebook
I have a dell D800 it won't power on at all the battery show full
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Dec 11, 2008 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell Latitude D800 Notebook Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
