Question about ViewSonic E70fb 17" CRT Monitor
Hi what is the model number for an e70fb backlight? i need to replace
  • 11,361 Answers
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Posted on Sep 07, 2010
I need backlight for this LC320WXN (SC)(B!) model screen. and where can i get it
Go online and Google you make and model number and the words replacement parts.
Oct 12, 2016 | Televison & Video
TV no picture I did replaced T-Con board and Power supply board. but didn't work it no backlight but This TV had no backlifht and inverter board in the back...needed help please.
Hi Tong,
Any basis or reason to replace the two boards you replaced? Any voltage measurement? Further you have not mentioned the make and the model number.
Generally it is the inverter board that is found defective in 'no backlight' problems. If the power supply is producing necessary voltage and the main board is sending necessary command ie 'inverter on' and 'brightness control' to the inverter board and still it not producing the voltage required to drive the backlight, the inverter board is defective.
Good luck.
Apr 29, 2016 | Televison & Video
We can't see LED light chip directly
Post the laptop manufacturer name, and model number.
The model number is on the Bottom of the laptop.
Post in a Comment.
Plus add additional info about what are you referring to?
Offhand, I would guess a reference to the LED backlighting on the laptop.
If this holds true, and you have no Backlight, the normal procedure is to replace the LCD screen.
With most laptops utilizing LED's as a Backlight, the LED backlighting is incorporated into the LCD screen assembly, and that's why when the LED backlighting goes bad, the LCD screen itself is replaced.
Post back in a Comment.
Regards,
joecoolvette
Jan 23, 2013 | Computers & Internet
My View sonic E70fB displaying OSD lock how can i remove it please help me sir
press and keep pressed upto 10 to 20 seconds the unlocked messege will appear problem will be solved
Sep 11, 2011 | ViewSonic E70fb (Black) 17 in.CRT...
My monitor(view sonic e70fb ) is osd lock, n how how can get unlock
Hi Mandalavijay,
To unlock your monitor you need to hold two keys simultaneously for about 5 seconds.
In this case for your model you need to press the 1 key and the down arrow key and a message will appear which reads ' OSD Unlock'
Hope this helps...:) Your feedback would be appreciated.
Aug 22, 2011 | ViewSonic E70f 17" CRT Monitor
I am having viewsonic E70fB monitor. brightness and contrast automatically increases. i want a solution to solve this problem
In most cases this could happen because of electronic components getting aged. I suspect the monitor's LOT or some capacitors about to die. Get them replaced with the help of a expert technician. That should fix this problem.
Mar 02, 2011 | ViewSonic E70fb 17" CRT Monitor
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
ViewSonic E70fb 17" CRT Monitor Logo
64 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
