Question about GE DWSR463EGWW Electric Dryer
I have a dryer model # DWSR483EB1WW (General Electric) that squeaks really badly. It almost sounds like metal rubbing metal, what could it be?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 10, 2010
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
Squeeking noise are the barron going bad
Squeaking noises are NOT necessarily an indication of bearing failure - but could be an indication of a slipping belt or something else rubbing. The machine itself may be rubbing against a washer, wall, door jamb, or anything really.
Look around the machine. See if it is in contact - or close to ant of these things. When it is running - it could be bumping against something. If nothing is found - have a look inside the the dryer. Inspect the belt and clean the drum where the belt tracks. Repl;ace the belt it is ready to break, missing parts or de-laminating. If you find shiny metal filings - that indicates metal is rubbing somewhere and is likely to be the cause of the squeak.
Good luck.
Apr 14, 2011 | GE Dryers
When you start our dryer up it sounds like it is rubbing metal on metal. It has a a horrible sound.
heatman101
Jan 31, 2011 | Frigidaire FEQ1442ES Electric Dryer
GE Model DDE7200RALWH squeaks like a metal on metal sound.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | GE DBSR453EBWW Electric Dryer
Grinding noise when it gets hot. sounds like metal rubbing. barrings? still heats good
heatman101
Sep 29, 2010 | GE DSXH43EAWW Electric Dryer
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
DRYER SQUEAKS REALLY BAD UNTIL WARMED UP
I took apart the dryer, cleaned and greased the bearing that had no grease left at all(therefore I assumed no easy movement) and it worked.
Dec 26, 2008 | Frigidaire FER231A Electric Dryer
GE DWSR463EGWW Electric Dryer Logo
418 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
