Question about Sansui DTV2760 27" TV
I was watching a DVD and then all of a sudden, the screen changes colors between normal and green
  • kahanu07 Sep 07, 2010
    So will I need to call a repair person to come out and fix this.The TV is barely a year old
  • 5,807 Answers
Have the unit unplugged for a while and plugged it back later.
If it resolves your problem and goes back again,
you may have a Video Circuit problem from the
CRT Board, could be a cold solder joint on Green Out
Drive , CRT socket or from the Jungle IC that
drives the Green Video Out Transistors
Posted on Sep 07, 2010
  • Rommel Cana
    Rommel Cana Sep 07, 2010
    It happens , But if the Unit is still under warranty might have a
    visit on your dealer,
    After checking all your connections, connectors are OK.
  • Rommel Cana
    And Don't open the unit , if it is under warranty.
Frozen screen
Unplug your cable box from the wall outlet. Wait 3 or 4 minutes and plug it back in.....TV should now be normal.
Sep 06, 2014 | Televison & Video
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
All of a sudden, the color changed to a blue/green...
You might have brought the magnet near the screen so it happened like this it will automatically adjusted after few days
May 20, 2010 | Computers & Internet
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
TV color changed to display green only
IF THE GREEN IS ON ALL INPUTS, THEN YOU WILL NEED A DIGITAL AND ANALOG BOARD REPLACEMENT, VERY EXPENSIVE REPAIR, TRY HDMI INPUTS FIRST, THEN COMPONENT AND SO ON
Dec 30, 2009 | Samsung HLT5089S Television
Color sudden change
Good day.
Your unit is still worth. It may be a caused of loose contacts along the circuitry. It can be remedied by resoldering the terminals particularly the chroma section and the crt circuit.
chris
Mar 25, 2008 | Toshiba 36A61 36" TV
Bizzare Color Problem
I normally find that the DVD is either in the progressive scan or interlaced mode. If the DVD is in analog inputs (video inputs), then, it should be in the interlaced mode. If the DVD is in the component input, then, it should be set to the progresive mode. On older DVDs, the switch to turn it to the proper mode is on the back or bottom of the DVD. Newer units are on the remote that says progressive or on the menu of the DVD. The owners manual should have instructions on how to change it.
Sep 01, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Sansui DTV2760 27" TV Logo
26 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
