Question about RCA DRC8335
Tray will not open: Samsung HT-BD1205 Blue ray home theater system After turning on the unit the display says "open" then after a few seconds it says BD/DVD. TRAY WILL NOT OPEN when touching the eject button or from the remote eject button. You do hear it beep, but nothing happens. Does this mean the unit is not communicating with the DVD or the DVD itself bad ? Is there a way to fix this problem without sending it to a repair shop or replacing the DVD player itself ? Note: the plastic drop down cover ( hinged beauty cover/door - what ever you call it ) is missing from the casing that`s in front of the DVD tray. Could this be the problem, does it have a censer ? Can not open to insert a disc please help
ButtFuzz
  • 463 Answers
SOURCE: DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Posted on Feb 27, 2009
SOURCE: Samsung BD-P1500. Firmare update problems
I believe on startup, you need to hold the fast-forward button on the unit, until you see something about reset in progress...
Posted on Aug 25, 2009
  • 7 Answers
SOURCE: My DVD tray will not open, and with no disc inside
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. I had to do this on my unit and therefore I recommed leaving a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: dvd will not eject. tray will not open.
The DRC8052N / DRC8052NB / DRC8052NC DVD recorder (sorry cab209, not a PC) has had a LOT of problems. So many that RCA doesn't even list it on their site! There was a firmware upgrade that supposedly fixed this, but I'm having trouble finding it on the web.
As to how to remove DVD:
1) Try unplugging the machine and leaving it unplugged for 10 to 15 minutes. then (without plugging it back in) press the power button repeatedly. (I know it sounds goofy but it came from customer support. Theory: to drain all power) Plug it back in and try to eject.
2) Another owner suggested holding down the HDMI button on the remote. The "hello" mesage is an initialization/power-on routine, so my guess would be it was powered off with the disc in it?
3) Unplug it. Remove the cover (two silver screws on each side and three black screws on the back). Slide the cover off (to the rear). Take the four small screws out of the top of the drive (marked LOADER on mine. Lift out the DVD. Reassemble.
While you have it apart..... You might also look at the circuit board next to the drive in the center of the unit. It has a bunch of capacitors (black or blue, cylindrical, w/ X or Y stamped in the end). If any of these are no longer flat on the X or Y end or have yellow 'goo' on or around them, they have failed and are the source of your problem. They can be replaced, but it may be more cost effective to replace the entire unit.
Jim
Posted on Feb 03, 2010
xxchemlight
  • 144 Answers
SOURCE: The DVD drive won't eject (tray won't open). I've
well it sounds like it is possible that the drive may have taken a ****. you can try to stick a safety pin in the tiny hole in the front to force eject. But usually when a drive stops opening its because its failed. but double check your power cable and your ide or sata cables on the back of the rom inside the case.
also you can use any cd/dvd rom as long as it matches the cable in the back, either ide or sata
you can find them fairly cheap @
www.newegg.com
www.directron.com
www.tigerdirect.com
Posted on Mar 26, 2010
No blue ray
If I remeber correctly, the Samsung HT-Z310 is a dvd system.....not blu-ray. Won't play blu-rays - never has, never will.
Jan 01, 2014 | Samsung HT-Z310T Theater System
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
Jan 16, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jul 05, 2009 | Samsung Audio Players & Recorders
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Display reads OPEN LOCK when I try to open dvd tray.
Jun 26, 2009 | Samsung HT-DS610 System
Samsung HT-X20 disc tray won't open
while unit is unplugged, try holding down the power button on the main unit for 10 seconds.
Hope this helps!
Jun 23, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Need region free codes
You can try this one it worked on my home threater system
  • Power On with empty tray (No Disc will be displayed in the DVD control panel)
  • Press the Enter button on your remote control
  • Press the buttons 8, 4, 2, 6, 9 and Enter button on your remote control
  • Tray will Open automatically
  • Close the tray on the DVD player
  • After 15 seconds have elapsed, power Off your player (switch the unit to stand-by mode) and then power On your player
  • Finished and ready to play all regions
hope this helps
Little Dish Fitter
Apr 20, 2009 | Samsung HT-TX72 Theater System
NEED TO UPGRADE MY HT-BD2 SYSTEM
There are two ways to approach this. You can either download the update from Samsung's support page, burn it onto a CD, place the CD into your Blu-Ray player and let the update load...or you can connect your Blu-Ray player to the internet and let the player download and install the update automatically.
For the first approach, the upgrade file can be downloaded by clicking on the following link:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149020&CDCttType=FM&ModelType=N&ModelName=HT-BD2&VPath=FM/200903/20090318095607437/081227_01_HT_BD2_XAA.zip
...and the instructions to installing the file on your system can be found here:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149021&CDCttType=FM&ModelType=C&ModelName=HT-BD2&VPath=FM/200901/20090109105847140/HT-BD2_System_Upgrade_by_CD_Method.pdf
The second approach is detailed in the HT-BD2 User's Manual (pages 46-49). It requires you to first plug a network cable into the back of your Blu-Ray home theater unit, then connect the other end into a LAN connection on your wall (or into the back of your cable/DSL modem) Page 26 of the user's manual shows you how to make the connection.
Apr 05, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
RCA DRC8335 Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
