Question about Ecoquest Fresh Air Air Purifier
Replaced bulb, plate and starter and get error code of "/0/?0...." something like that anyway, but no other screen appearances,fan speed purification levels. do get a series of bars across entire screen sometimes.
  • dalefoland Sep 07, 2010
    how does the lcd panel on front of machine come out? seems to just snap in.
Clean the filter and then unplug your unit from the wall for one hour and then plug it back in and the error code will go away, click on the link below to view manual:
http://www.fixya.com/support/p539338-ecoquest_fresh_air_air_purifier/manual-20082#
Posted on Sep 07, 2010
  • 3,083 Answers
It sounds like a bad or loose hookup to the display panel, or faulty display panel. On the following web page Ronald mentions bad lcd's and other faults:
http://www.consumeraffairs.com/health/ecoquest.html
Not much good news, since they went out of business and got taken over, and apparantly is not supporting customers.
Anyway, good luck, hope this helps, and thanks for using FixYa.
Fresh air 2, blue light goes out, fan still works, reads
If the light goes out, it is time to replace the bulb AND the bulb starter. They need to be replaced every two years. Beyond that, they are an expensive night light. If you need to order one, call (336) 499-2505. Also ask for supplemental cleaning instructions since the original instructions are incomplete.
Jun 10, 2012 | Ecoquest Fresh Air Air Purifier
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
Can purifer work without the ozone card working
It will operate without a purification plate, as long as you are running in RCI mode or normal mode. If you normally run the purifier with some ozone output, then you will need a purification plate. Hope this helps you.
Feb 21, 2011 | Ecoquest Fresh Air Air Purifier
Do I soak the rci target plate in ammonia with the purification plate?
No, just rinse the RCI target with warm water. Allow it as well as the purification plate to dry completely before reinstalling into the purifier. You can speed up the drying process using a hair dryer at a low heat setting. Hope this helps you.
Feb 11, 2011 | Ecoquest Fresh Air Air Purifier
No my Breeze AT no longer gives me the Ozone smell.. what can be possible causes
Remove the purification plates and examine them for damage. If they are cracked, then they need to be replaced. Try cleaning the purfication plates with a solution of one part warm water and one part amonia. Take a old toothbrush and dip it into the amonia solution and scrub the metal grids on the purification plate. If there are deposits on the grids, scrub them until they shine and do both sides of the plate. Scrub the metal contacts that touch the plate as well. Rinse off the plate with tap water and allow it to dry completely for 24 hours or use a hair dryer to dry the plate.
Check the wiring that connects the purification plates for corrosion, that will often lead to problems.
Dec 06, 2010 | Ecoquest Breeze AT Living Air Purifier
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
How far in do the plates go and are they supposed to make a noise?
They should go as far so the back edge of the plates touch the back stop and the the metal clip on each side of the plate is touching the metal screen on the plate.
As far as noise, depending on the purification setting, they can make a hissing sound. If you see arcing or sparking, or hear any other noise other than a hissing sound, then it is time to replace the plates.
Hope this helps.
Jul 18, 2010 | Alpine Air XL-15 Air Purifier
I have two that quit the ozone part. Just the fan works. I have a XL 15 and 880, that I can still smell just a little ozone. Can I fix these myself?
You might be able to fix them.
There a couple of things that can go wrong with these units, dirty plates, bad contacts, and bad reostat.
Dirty plates:
The ozone is generated by the purification plates. They should be cleaned once a month with a solution of one part amonia and one part tap water. Use a soft bristle brush like an old toothbrush and scrub the metal contacts on the plates with the amonia solution. Be sure to do both sides. Allow them to sit with the solution for 10 minutes, then rinse off with tap water and allow it to dry completely.
Bad Contacts:
There is a couple of metal strips that make contact with the purification plate. Check the contact strips and wires for corrosion. The metal strips can also be cleaned with the amonia solution as well.
Bad Reostat:
The reostat is the part that attaches to the control knob that sets the purification levels. Sometimes it can go bad. The easilest way to check them is to use a meter and verify that as the knob is turned that the resistance changes with the position of the knob.
Jul 16, 2010 | Alpine Air XL-15 Air Purifier
When sliding in the plates I noticed they come in contact with a steel like wire in the back. Is that correct or should they not come in contact with them?
It is normal for the purification plates to have contact with the metal contacts. The metal contacts provide the electrical power to operate the purification plates.
Jun 13, 2010 | Ecoquest Flair Air Purifier
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
29 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
