Xerox call for service
Did you get a solution to your problem? I am having the same message, but I did not understand the solution that said "fdgf fgh ddfh df ". I would appreciate any help. You can reach me at 615-765-3110 or at washintorah@yahoo.com. Thanks, Tom Washburn
  • 239 Answers
I have worked on these machines.
Try to take out the main board. Two screws on the side and it slides out.
Re-enter it and plug the machine in, and power on.
If the machine does not come to a ready, try these.
Hold the menu, 1, 3 and 0 button, then power on. hold the buttons for about 10 seconds
We are trying to re-set the main board NVM values.
If not try menu, 1, 3, *.
or menu, 1, 3, #
if non of these work, and the machine menu is frozen, you are looking at a new main board for the machine.
let me know if you had any luck. I still need more information in order to resolve this problem.
Posted on Oct 26, 2009
  • 1,326 Answers
I don't know of that error code or model. You may have to deal with a Xerox dealer. It is almost impossible to get tech support from xerox. Good Luck
Posted on May 15, 2008
My printer is a docuprint 205fw and cmes up with a 016 - 502 error
Page 419 of the manual says to contact an authorized dealer after turning the unit off and then back on, if the error persists.
Xerox DocuPrint CM205 User Manual Understanding Printer Messages then refers you to page 465 "online services"
Dec 07, 2016 | Office Equipment & Supplies
The plastic sleeve abo;ve the metal gate valve got striped do you have a metal sleeve to replace? I used this wand on the end of a 10 foot galvanized 1/2" pipe with a metal adapter . do you have a metal...
Hey there
this design seems ok but then they put a plactic adapter on the end...fail. on the inside of that plastic adapter you should be able to use a hex socket to remove from you extension wand. I suspect that the threading is 3/8" or possibly 1/4". You should then be able to match that up at a local pressure washer dealership. It will be 1/4" MPT x 3/4" FGH or 3/8" MPT x 3/4" FGH. Im guessing by looking at a picture of your wand only so still take this adapter out and check to verify the size. If you are having trouble finding the adapter then check here.
Pressure washer parts catalog quick links Pressure Washers High Pressure... Give them a call and they can help. The item numbers you are looking for are
1/4" MPT x 3/4" FGH Item # 3250
3/8" MPT x 3/4" FGH Item #3251
Good luck
Feb 24, 2015 | Orbit Telescoping Gutter Wand Set
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
How do i change the print head on a Xerox 8560
Is not a simple job, but also is not something from another world. You can do this with the right tools and a little bit of patience.
I recommend you to read carefully the service manual (printhead section) to understand what steps you should follow. You can download it here: http://www.download-service-manuals.com/manual.php?file=Xerox-1782.pdf
Hope it helps.
Aug 18, 2010 | Xerox Phaser 8550DX Laser Printer
My samsung flip phone, model no FGH/ZV40 is receiving calls but not text messages.
Try to call your service provider to check the configuration settings for your text messages. Asked them to refresh your account and verify the message center settings on the phone.
Jul 04, 2009 | Samsung Cell Phones
Service message: Fault 37,004,40:50081
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
May 22, 2009 | Xerox Phaser 8400 Laser Printer
Pls reply
fghfghfg fgh fgh fgh fgh fghfghgf fg hfgfgh fg
Aug 27, 2008 | Acer Aspire 5100 Notebook
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    47 people viewed this question
    jasbo
    jasbo
