Question about Delta Faucet Home
Have installed a Delta 142910-ss and having a problem with the water getting only warm and not hot.
    Problem Solver:
  • 14 Answers
If it's an old Delta, then there's a set screw on the valve behind the plate. If it's the newer version, then there is a notched plastic piece behind the handle.
Posted on Mar 07, 2011
Water line
As a rule of thumb the water line to the right is the cold water line.
Apr 19, 2014 | Delta B4310LF-SS-SDISP Foundations Core-B...
Delta Touch2O problems
YOU HAVE A COLD WATER RESTRICTION SOMEWHERE. THROW A DIFFERENT FAUCET ON THERE, AND SEE HOW THE FLOW IS. MY GUESS: STILL POOR....TRACE COLD LINES BACK UNTIL YOU FIND IT
Dec 20, 2013 | Plumbing
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
Is there a way to reverse hot and cold?
Is it moen brand? if so all you have to do is take off the handle and remove the cartridge inside and flip it over 180deg and put it back in.
be sure to shut the water off first.
hope that helps you.
Dec 18, 2012 | Delta 144962-SS Mandara Monitor 14 Series...
Our hot and cold water seem to be mixing. we had scalding hot water for a few days,then hot water tank died. put in a new one and now the water is warm for a minute then turns very cold.
When you filled the water heater did you get all the air out of lines and water flowing before you turned power onto heater. It sound's like the bottom element on the heater is not working. That is if it's the same throughout the house hot then get's cold.
Check the power to the lower element and thermostat.
Jul 09, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
No hot water from Delta T13020 contro
Try reinstalling control valve in opposite /reverse position this should be the correct position.
Mar 17, 2009 | Plumbing
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Home Logo
304 people viewed this question
Top Delta Faucet Home Experts
john h
bobalix
bcas6924
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
