Question about Texas Instruments TI-84 Plus Calculator
When i click graph it says "ERR: INVALID DIM" i noticed under "y equal" mode that plot 1 and plot 2 are highlighted. how do i fix this, i need to be able to graph. TI-84 plus calc.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Sep 06, 2010
How to fix INVALID DIM in plotting graph
The ERR:INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press y ,and
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Apr 05, 2014 | Texas Instruments TI-84 Plus Calculator
When I try to graph it says-ERR:INVALID DIM 1:QUIT
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
When I press graph, it says "ERR: INVALID DIM" how
Jan 14, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
Jan 05, 2011 | Texas Instruments TI-84 Plus Silver...
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
When graphing says ERR: INVALID DIM 1:Quit
You have two lists that don't agree in length.
Solution 1 (easy)
Press [y=] and look at the top line - one of your Plots is highlighted.
Move the arrow to the highlighted one, press enter to get it un-highlighted.
Solution 2 (permanent)
Press [STAT] - EDIT: [1] to edit your lists. Go to the bottom of the lists and see which one is the longest. Delete (DELETE, not clear) the "extra" entries in the longest list until all lists are the same length.
Oct 04, 2009 | Texas Instruments TI-83 Plus Calculator
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
252 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
