Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
This is the second time in less than 1 1/2 years that the lower flexible drive shaft has broken. Any ideas?
    Guru:
  • 1,051 Answers
My suggestion is to complain to Troy Bilt. The company is actively trying to increase it's market share and may be very willing to provide a new unit.
Posted on Sep 06, 2010
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
How to replace the lower flexible shaft
Hi enriquemon,
To remove the drive shaft, loosen the clamp that is just above the protective shield and remove the set screw attaching the drive shaft tube to the trimmer housing. Remove the drive shaft and if you want clean and inspect for damage. You are installing a new one so it is not an issue. Coat the shaft with a high quality, multipurpose lithium grease. Make sure the ends of the shaft are properly located in the drive adapters when assembling. Depending on the amount of time it is used, the drive shaft should be cleaned and greased every year or two. I hope this is helpful to you. Any questions welcome. All the best and good luck.
Feb 19, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
89 chev s10 how to replace front axles
prev.gif next.gif Halfshafts (Drive Axle) REMOVAL & INSTALLATION Fig. 1: A torn CV-boot requires removal of the driveshaft for overhaul 85387081.jpg
Fig. 2: On most vehicles. the caliper should be removed and supported out of the way 85387082.jpg
Fig. 3: Also on most vehicles, the tie rod end should be separated from the steering knuckle 85387083.jpg
Fig. 4: Once the lower shock fasteners are removed it may be compressed and wired up out of the way 85387084.jpg
Fig. 5: Loosen and remove the flange bolts 85387085.jpg
Fig. 6: Remove the cotter pin and retainer so the axle nut may be loosened 85387086.jpg
Fig. 7: A prybar may be used across to of the lug nuts in order to keep the hub from turning while loosening the nut 85387087.jpg
Fig. 8: Use a suitable axle shaft removal tool to drive the shaft from the hub 85387088.jpg
Fig. 9: If a driver tool is not available, thread the nut just flush with the shaft end and tab gently with a rubber or brass mallet 85387089.jpg
Fig. 10: During assembly, hold the hub from turning and torque the axle nut to specification 85387090.jpg
FRONT DRIVE AXLE Identification The front axle assembly used on most 4wd models covered by this manual utilizes a central disconnect type front axle/transfer case system which allows shifting in and out of 4wd when the vehicle is moving under most driving conditions. The axle has an aluminum carrier which includes a vacuum activated center lock feature. The axle on the MFI-Turbo is designed for full-time four wheel drive and therefore is not equipped with a disengagement feature. With this one exception, the MFI-Turbo and standard 4wd front axle assemblies are very similar. The drive axles employ completely flexible assemblies which consist of inner and outer constant velocity (CV) joints connected by an axle shaft. The inner CV joint is a "tri-pot'' design, which is completely flexible and can move in and out. The outer CV joint is a "Rzeppa'' design which is also flexible but cannot move in or out. NOTE: For more information on front axle identification, please refer to Section 1 of this manual. prev.gif next.gif
Jul 21, 2010 | 1988 Chevrolet S-10
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
Cub Cadet 129- The drive shaft from the engine to the hydrostatic drive does not line up at the hydro end. What should I do? The roll pin in the shaft at the engine hub it connects to kept shearing, and...
This mis alignment of 1/4" is about normal that is how and why cub put the rubber flex coupling on the hydro... however if there is play in the hyro input shaft then we need to determine what the cause of this is. Good luck
Sep 07, 2009 | Cub Cadet Garden
Fix the flexible drive shaft has a problem
The Metal Clamp referenced clamps directly on the end of the '2-Piece Gear Box Assembly'. The gear box assembly is an aluminum casting held together by 3 machine screws. The Metal Clamp does not actually lock the drive shaft housing into the gearbox assembly. The flexible drive shaft cable engages the engine output shaft, and the gear box assembly. This is a fixed length (non-adjustable) assembly.
First ensure that the drive shaft assembly is fully engaged at the quick connect fitting and that the "snap" is engaged. Then make sure the knob is fully tightened. The quick connect allows you to quickly switch between various attachments offered on this unit.
Now, based on your description, it sounds like the 'anti-rotation screw' 791-182519 has backed out or is gone. This will allow the entire cutting assembly (gearbox forward) to slip off of the drive shaft housing and disengage the flexible drive shaft. If your cutting assembly is attempting to rotate while in operation, or the drive is not engaged as you described.
Do not continue to operate the unit until you get this fixed as you could strip out the drive shaft end or cause other serious damage to the equipment or yourself.
If it is the anti-rotation screw, then make sure to push the drive shaft housing firmly into the gear box and ensure to align the holes in the drive shaft housing and the gear box. If the screw is lost, then find one similar sized, but be CERTAIN that it is not too long as it will actually engage the flexible drive shaft and prevent rotation, or cut the drive shaft.
Back to the clamp: If it is still wanting to move, then remove the lock nut and place slightly oversized washers on the bolt head and the lock nut. This will force more pressure (does not take much) on the clamp and will lock it down.
I just fixed mine today (071809) in fact and had to drill a new hole in the drive shaft housing as the original was completely wallowed out.
I hope this helps.
DROPNDEAL
Jul 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the...
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Jun 22, 2009 | Garden
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
124 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
