Question about Vizio Televison & Video
Have a vizio model M190VA 19in. tv. NO SIGNAL is on the screen.
  • Vizio Master
  • 5,126 Answers
What source is connected to the TV (what input is it looking for)? Check that the cables are fully connected and undamaged. If the source is a set-top box or dvd player, make sure the device is on and works for another TV. If the source is OTA, make sure the antenna is pointed in the correct direction and is getting sufficient signal. (Try antennaweb.org or tvfool.com for antenna direction and signal strength. Antennaweb is very conservative in the list and assumes an outdoor antenna.) If you have an amplifier or splitter, try eliminating them to test just the one tv (I've had several amplifiers turn into filters that blocked one station after lightning strikes). Try rescanning for channels.
Try another station or source. If none of these ideas help, you may have damage to the video input board or a problem with the cable from that board to the rest of the TV. If the tv is out of warranty, open up the unit and remove the shielding. Look at the boards for obvious damage (soot, scorch marks, leaking capacitors (look like cylinders on tripods)). My usual source doesn't list parts for this model TV but you may be able to find the board with the part number on the board itself.
I hope this helps.
(I use shopjimmy.com for reclaimed parts with minimal use)
Posted on Sep 06, 2010
Tv onn sin audio
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 30, 2014 | Vizio Razor M190VA 19-inch 720p LED TV...
I don't have cable. Do I need an antenna to be able to get any channels in this area or does the TV have an internal antenna?
Go to TVFool.com and it will tell you what kind of antenna you need and what stations you can receive according to your address.
Oct 20, 2014 | Televison & Video
Can i turn my vizio m190va tv into a computer monitor?
Unfortunately. the HDMI port on the M190VA does not interpret the signal from a computer. The HDMI signal from a set-top box is different than that of a computer. You need to use the VGA port and the PC audio in on the TV; if your computer doesn't have a VGA port, use a DVI to VGA adapter or other appropriate adapter. You will need a 3.5 mm audio patch cable to use the TV's speakers. See page 25 of the M190VA manual here: http://store.vizio.com/documents/downloads/hdtv/M190VA/364User%20Manual.pdf .
I wish that I had better news for you.
May 08, 2012 | Vizio M190VA 19 Class Edge Lit Razor LED...
How to turn my vizo off manual
Hello
Get into this link to download the user manual to your Vizio TV.
vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Jan 19, 2012 | Vizio L32 32 in. LCD HDTV
I have a Vizio M190VA LED tv. Once i plug it in it will come on and then turn off by itself after about 5min. It will not turn back on unless i unplug it and plug it back in. Please help. I am farely tech...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
May 18, 2011 | Vizio M190VA 19 in. LCD TV
A message is on my screen that says, "Video 5 HDMI is not supported
Whatever you have plugged into HDMI 5 is set to a resolution that exceeds the TVs ability to display. Try setting the source to 720p or 420p
Mar 12, 2011 | Vizio M190VA 19 in. LCD TV
I can hear sounds but no photo on my 19in vizio lcd tv but the scrteen it only stays on for 2-3 seconds but the sound stayes on as long as you want
Take a bright flashlight and place it on the screen. Around the edged of the flashlight see if you can see an image moving around on a good channel. If so you need an inverter/lamp repair/replacement.
Feb 13, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
Goldstar 19in TV
First check if the signal source is Ok - Antenna, cable, Cable connector.... One of them is at fault.
Sep 26, 2006 | Sony KV-35V35 TV
Televison & Video Logo
193 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
