Question about Samsung SL620 Digital Camera
When i turn my camera on the shutter wont go in and it makes 3 beeping noises.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 06, 2010
My camera makes a beeping noise EVERY time I push a button on it! It's really annoying! How do I turn the beeping noise off???
Tap MENU to bring up the menu screen. Tap the wrench tab to access the Setup menu. Scroll down if needed, and select "Sound Settings." Turn off the "Button Sound" and, if desired, the "Shutter Sound."
This is described in the "Sound Settings" subsection of the "Setup Menu" section of the manual (page 148 in my copy).
Apr 13, 2011 | Nikon Coolpix S4000 Digital Camera
How do you stop the beeping sound when you press the menu biuttons etc e.g. like to view your pictures etc on the SONY Cyber-shot DSC-W350 ? it is really annoying to hear the beeping every time you...
I have a W560, but maybe it's the same on your camera. It was driving me insane as well. On my camera, I went to the menu, under Main Settings there was something called "Beep." It gave the options of "Shutter, High, Low, and Off." If I chose Shutter, then it keeps a shutter-like noise when you take a picture but turns off the annoying beep whenever you push any other button. I assume if you choose Off it will turn off all noises.
Hope that helps!
Jan 07, 2011 | Sony Cyber-shot® DSC-W50 Digital Camera
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
Sep 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Samsung SL620 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
