Question about Toshiba 20AF41 20" TV
Tv will not come on
When trying to turn set on with comcast cable remote or manually, tv just clikcs. cycles a few times then clicks again and so on. has been doing this for several hours. not on as of yet.
  • rgail Dec 28, 2008
    just ckicks and won't come on
  • pmurko Jan 02, 2009
    Exactly the same problem. I can not believe the power supply is shot. The TV worked great until the 3rd time this happened. My research indicates the power supply also. Toshiba should not allow this to happen. I am in the market for a new TV but I will not buy another Toshiba. Seven years old - this is absolutely the shortest time a TV has lasted for me. I am not willing to set a new low standard.
Well, sorry to say but it looks like it is a power supply. Over here we have checked everything and done some research and it looks to be the power supply. Go buy a new tv --_-- .........
Posted on Sep 20, 2008
What is the remote code for signature2000
I dont think there is a usable 1 listed in our instructions. So you will need to use the manual search option on your Comcast remote. With the TV on stand close to the TV and hit the TV button then hold the set button until the cable light flashes 3 times...let the button go and type 991 then 1 again now tap the channel up button slowly 1 at a time until the TV shuts off then hit the set button again to lock that code in. If you miss it try the process again.
Aug 21, 2014 | Comcast XFINITY
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
I got a new TV and want to get my comcast remote synched up
go to www.comcast.net and click on the Help link, you should be able to find the remote codes and instructions on how to program it...also do a google search for COMCAST REMOTE CODES.
Mar 15, 2009 | Sharp 27K-S100 TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Remote codes
Most remotes have a "Search for Code" or learn function. However, since Comcast currently supports 8 different types of remote controls, your best bet is their website. This link takes you to all of the remotes they currently support, find your remote and click on the View Manual link next to it.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
More than likely you will have to use the "Search for Code" option, as I did not see your particular TV brand on the few that I checked.
May 30, 2008 | Haier TN201AUV 20" TV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Nov 07, 2007 | One For All URC-9800 LCD Remote Control
Remote Doesn't Work for TV, but Works for TV
You might have lost the code from the remote which identifies the tv to your remote. If you have the manual that came with the remote you might try entering the code again. ( reprogram the remote). Stargazer
Feb 26, 2007 | Hitachi 32CX7B * 32" TV
Toshiba 20AF41 20" TV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
