Question about Whirlpool Washing Machines
Hi,have just bought a second hand Whirlpool 7244E,Super Capacity washer plus.The mounting plate (triangular)has mounting supports missing and when the machine goes to spin, whole motor mounting is slamming into fram,making one hell of a noise.? Regards Wayne
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to order your part for your washing machine:-
http://www.repairclinic.com/
Also check this link to diagnose your problem to the washer thoroughly:-
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
Or check the bellow link to contact the customer support for assistance:-
http://www.whirlpool.com/custserv/index.jsp
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 07, 2010
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Control locked.
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Feb 28, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I keep getting a dL and then a code F on my washer
LD = Long Drain ErrorRemove the 3 screws on the bottom kick plate, remove the kick plate. You will see the pump filter on the bottom right had side. Open the filter and remove any debris.
Feb 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have resently purchased a second hand super capacity machine, not yet run it. The softner receptor is very dirty and I was wondering how to clean it out. I have taken the top bit off but am unable to...
You can use vinegar to clean the machine take 100ml of vinegar and two buckets of hot water till the plastic tolerance then start the normal program the hole machine inner unit will be cleaned you can use the same process two months once the cloth cleaning quality will be good
May 17, 2010 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
