Question about Mirage OmniVibe Stereo Speaker System Docking Station, Speaker System for Apple iPod - 14020
The on off button does not work when pressed - it just keeps flashing. This is annoying, as the only way to turn off is to unplug.
    New Friend:
    Problem Solver:
  • 9 Answers
Hello, I have the exact same omnivibe but the volume decrease button did not work ( i bought it from a thrift store for 6$ for the electronic components inside but found out every thing worked except the volume matrix! ) anyways i pulled the sticker off the vol + / - and power bar to see what it looked like and it is just a simple two wire sensing pad. Heres what i did to fix mine - keep in mind that there are three possible reasons for your volume button not working:
1) the ribbon cord thingy with the metal strips inside the stereo makes the electrical connection from the sensor to the "mother board?" is damaged and not able to read that your pushing the button,
2) the connection from the ribbon to the 4 prongs directly on the mother board thing is loose/ damaged or dirty/dusty somehow and
3) the connection from the metal plate on the bottom of the sticker covering the volume + button that touches the wires underneath is dirty or faulty some how.
There is also the possibility that the "motherboard" is damaged but if the other buttons work then thats probably not the case, any way on mine the problem was the ribbon cable strip thing so i cut it off and made my own push button system that i will tell you how to make your self. ( you can do it my way which uses pushbuttons for all three of the ones on the iPod dock or you can just wire in one for the volume + but that way is harder and its a matter of time before the other two buttons go any way)
Materials needed - soldering iron, 3 push buttons from an electronics store ( small ones are better so they fit where the old vol +/- and power buttons were) some wire - 20/22 gauge solid wire, a drill and a bit thats the same size as your push buttons.
Step 1- take the screws out of the back so you can get at the insides- theres a hidden one behind the sticker with the all the warnings on it telling you not to take it apart! ;)
Step 2 - take the circuit board out and be care full not to touch any of the round capacators ( they look like little barrels) cuz they could shock you even after you've unplugged the stereo - which i hope you have already done!
Step 3 - unscrew the iPod dock from the back of the stereo case and peel the sticker off of the top - the one that says vol+/- and power - check to make sure its clean underneath, if it is then check the ribbon coming out of the bottom of the dock ( the flat wires you can see under the sticker go to the ribbon ) and see if there are any breaks or scratches or anything that looks like damage - if thats ok then pull the ribbon connection off of the circuit board and make sure the four prongs and ribbon connection are good- if all this looks good then clean prongs with a rag or something and put it all back together and see if it works now, if not then you will have to build your own volume and power control button which is what i did... and heres how...
1) take everything apart again ;) and drill three holes into where the vol + and - and power buttons were, make sure u don't drill into anything else like the red and black wires that are also there - you don't have a remote anyways so cut those white wires off that go to the remote sensor to make life easier and disconnect the speakers if you want.
2) cut the ribbon thing off as close to the iPod dock as you can and disconnect the black clip thing from the circuit board - it just pulls off but do it gently
3) remove the black clip from the ribbon - see the 4 holes in it that you can see silver tabs in? push those holes onto the 4 prongs and slide the ribbon out gently, you will then see 4 silver clip things attached to the metal in the ribbon - take those off gently so you can solder new wire onto them and reconnect to the prongs later, keep that black clip too!
4) OK now the fun part! cut 3 pieces of wire about 6" long and solder each one of them to each one of the terminals on the pushbuttons, cut another piece of wire about 6" and then 3 jumper wires that are 4" each, solder the three pieces together on one end so that you have 3 wires going into one and then solder that to your 4th 6" wire like this ( first pic at bottom )
5) Now solder that piece to the other terminal on the pushbuttons and you should have 3 pushbuttons all hooked up with 4 wire ends showing - remember those silver clips you cut off of the ribbon? u have to solder each wire end onto the end of each one of those - this is a bit tricky but doable!, when thats done place each silver connector into a plug on that black clip you took off the ribbon, the order is shown in the diagram - its not too important for the buttons but the top pronge on the circuit board is the one that must have the 3 to 1 wire attached to it the prong under that is volume + then power and the last one is Volume -, Now you should have something that looks like this... ( second pic )
Sorry about the crude drawings but it is the easiest way to show!
( where it says black clip with an arrow there should also be 4 holes where you pushed the old ribbon clips out from )
6) Well the hard part is done!! alls thats left is to place your push buttons up through the holes you drilled earlier, you can put them however you like i.e.- power then volume down / up or what ever- i hot glued mine in from underneath cuz i drilled to big but hopefully you can screw yours on properly depending on what push buttons you got.
7) Now connect your black clip with all the wires into the prongs on the circuit board - make sure your in the right orientation with the three to one wire being in the top prong ( the one furthest away from the dock) and the 4 holes in the clip facing out.
8) Now put everything back together and plug it in and test out your new home made push button matrix! if it dosnt work then you will have to check your wiring and soldering again.
I truly hoped this helped ya out!, i spent about two weeks figuring this one out and in the end i built a new box to house the speakers and circuitry so it would look cooler, but the pushbutton matrix is much more reliable and durable then the one that was installed originally!
Enjoy and Good Luck!
The on off button does not work when pressed - it - 36119765-eac4-48c8-890d-5e5d9bb3a605.jpgc98afcea-df07-47d8-a952-6c1c59866909.jpg
Posted on Dec 24, 2013
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Before doing Resett ,Printer must be Ready (Service mode) , How to service mode;
  • Turn off Printer ( POWER + USB cable attached).
  • Press and hold RESUME button? .
  • Press and hold POWER button then free RESUME button But hold POWER button .
  • Press RESUME button five times (5x). not 4xprinter will turn off, but temporary.
  • Free both of button , the lamp indicator will ready in green /ready (printer will Found new hardware = canon device) Annoy it
  • Service tool v_1074.exe
  • Pairs of paper in the printer.
  • Find CLEAR INK COUNTER colom then click MAIN .
  • Printer will print
  • Turn off printer.
  • Turn on printer .
  • Printer is ready for use.
Reset Canon iP2770 error 5200
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal
download: http://www.ziddu.com/download/14828683/ServiceTool_V1074.rar
Aug 29, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Oct 08, 2009 | HP DeskJet 9800 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Printer Error Message HP AIO 6210 printer
Hi
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
Riz
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cl and 0 flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Dec 28, 2008 | Uniden Cordless Phone
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
KEEPS FLASHING
press the voicemail button and then press the line button. The voicemail button usually turns off at this point if there are no messages...
Jul 23, 2008 | GE 29460GE2 Corded Phone
HPc6150 printer error
Hai
I Seems to be a hardware problem.Follow my troubleshooting steps.
STEP 1:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.(if it doesn't works goto step2)
STEP 2:
PARTIAL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
STEP 3:
SEMI_FULL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
STEP 4:
(Notes - resets will take a while)
If they don't work, the printer needs to be serviced.Let me know the status.
Thanks
Riz
May 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Mirage OmniVibe Stereo Speaker System Docking Station, Speaker System for Apple iPod - 14020  Logo
154 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
