Question about HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only
Lens Error M425-12 (7F80) on HP M425
My HP M425, just keeps sating this on it's screen when I turn it on, it isn't a power problem, but it turns itself off after a few seconds
  • 1 more comment
  • Anonymous May 17, 2008
    2 cameras M425
    My #1 HP
    Hi..same camera, same problem.( Lens Error M425-12 (7F80) on HP M425).
    my second camera(same M425) same problem, but this one the lens is out, went the power it turns itself off,the lens still out.
    Thank you
  • Blackwolf194 Dec 14, 2008
    I bought this for my daughter 2 Christmases ago, now today she brought it to me with the lens out and the "Lens Error (M425-12 (7f80). New batteries and removed the sd card, restarted the camera, an then inserted the sd card after it was powered down. No luck.
  • Anonymous May 06, 2009
    it does th same error when i turn it on it says the same error
When i turn it on it say lens error and i got hp m425
Posted on Mar 23, 2009
Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
Posted on May 15, 2008
2 Suggested Answers
  • 102366 Answers
SOURCE: Lens Error M425-12 (7F80) on HP M425
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
Lens error lens wont close what to do?
Hi,The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Here are different solutions to this problem;
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Thanks and take care
Apr 25, 2010 | Nikon COOLPIX L18 Digital Camera
M425-12 lens error
Jul 29, 2009 | HP Photosmart M425 Digital Camera
HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only Logo
724 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
