Question about Maytag 24 in. MDB4100 Built-in Dishwasher
My dishwasher is filling up with water but it is not cleaning dishes. the lower spray arm is moving but has limited pressure. The top sprayer is barely moving. Water gets hot but seems as thought the pressure is not good to cllean the dishes.
  • Maytag Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
agf23
Posted on Sep 29, 2010
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
The dishes on the top are not getting clean what can be the trouble? Tea stains and grit are left in cups and glasses.
DISHES ARE NOT COMING CLEAN BYPASSED THE DOOR LATCH TO WATCH CYCLES,LOOKS LIKE THERE IS NOT ENOUGH WATER PRESSURE TO ACTIVATE THE WATER TOWER AND ROTATING ARM?WATER PUMPS OUT BUT NOT ENOUGH TO MAKE THINGS...
Aug 24, 2009 | Dishwashers
Cutlery on top tray is not cleaned - comes out with food still stuck here and there - rest of the content is clean
Aug 24, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Our dishwasher is type no:575-0, model:665.17369301.dishes r not getting clean properly.
This may help you.
Aug 22, 2009 | Dishwashers
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
124 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
