Question about Car Audio & Video
I need to assemble the parts removed after installing a rebuilt transmission, my mechanic died
    Master:
  • 373 Answers
What type of vehicle and what is left undone
Posted on Sep 06, 2010
Where is the transmission temperature censer located on a 2003 Buick regal?
(391) Automatic Transmission Fluid Temperature (TFT) Sensor
Inside the transmission behind side cover
Removal Procedure
Remove the case side cover. Refer to Control Valve Body Cover Replacement .
Important: Lock steering wheel in centered position with wheels straight ahead.
Remove the engine dress cover.
Remove the air cleaner intake duct. Refer to Air Cleaner Inlet Duct Replacement in Engine Controls - 3.1L or Air Cleaner Inlet Duct Replacement in Engine Controls - 3.8L.
Remove the engine mount struts. Refer to Engine Mount Strut Replacement in Engine Mechanical - 3.1L or Engine Mount Strut Replacement - Right Side and Engine Mount Strut Replacement - Left Side in Engine Mechanical - 3.8L.
Important: For supercharged engines, remove the throttle cable bracket.
Disconnect the shift cable bracket.
Remove the transaxle top side cover bolt.
Install the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical - 3.1L or Engine Support Fixture in Engine Mechanical - 3.8L.
Disconnect the transmission wiring harness connector.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the left front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the left inner splash shield 3 push pins.
Loosen the wheel speed sensor harness from the 5 retainers at the cradle.
Remove the transmission support to cradle nuts only. Refer to Transmission Mount Replacement .
Raise the vehicle.
Remove the front splash shield 5 bolts.
Loosen the engine mount lower nuts. Refer to Engine Mount Bracket Replacement in Engine Mechanical - 3.1L or Engine Mount and Bracket Replacement in Engine Mechanical - 3.8L.
Remove the stabilizer bolts and reposition the stabilizer.
Remove the steering gear cradle bolts, then support gear before lowering cradle.
Support the left side of the frame with a jackstand.
Remove the left side frame bolts. DO NOT loosen the right front or the right rear frame bolts. Refer to Frame Replacement in Frame and Underbody.
Remove the left ball joint from the steering knuckle.
Position the drain pan under the transaxle.
Remove the left drive axle from the transaxle. Refer to Wheel Drive Shaft Replacement in Drive Axle.
Secure the drive axle to the steering knuckle/strut.
Adjust the jackstand to lower the left side of the frame until it hangs free. Remove jack stand.
Lower vehicle to access engine support fixture.
Lower the engine/transmission assembly with the engine support fixture to gain access to remaining side cover bolts.
If replacing the side cover, remove 4 engine mount bracket bolts.
Remove the harness retainer.
Raise vehicle to access side cover bolts.
Remove the case side cover bolts (56-58).
Remove the case side cover pan (53).
Remove the case side cover gasket (54).
Clean the case.
Clean the side cover gasket mating surfaces.
Disconnect the wiring harness assembly from the fluid temperature sensor (391).
Remove the fluid temperature sensor (391).
Installation Procedure
Install the fluid temperature sensor (391).
Connect the wiring harness assembly to the with fluid temperature sensor (391).
Install the case side cover. Refer to Control Valve Body Cover Replacement .
Important: It is recommended that transmission adaptive pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, The ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Reset the TAP values. Refer to Transmission Adaptive Functions .
Nov 23, 2016 | Buick Cars & Trucks
2003 F-350 7.3 diesel Fx4 Automatic Transmission. After installing a quality rebuilt transmission, I went for a test drive. During the test drive, the transmission shifted smoothly through the first two...
That quality transmission may have a shorted shift solenoid or the wiring harness to the transmission is shorted or the control module is defective.I would strongly suspect the wiring is the problem, check every inch of it for damage like touching the exhaust and so on.
Mar 24, 2017 | Ford F-350 Cars & Trucks
Have no reverse in transmission but it will go in to drive fine
No reverse is the first sign of a failed transmission. You will need to remove it and have it rebuilt or just get a remanufactured one and install that. Use quality parts, not the cheapest price one, use OEM parts and that includes a rebuilt transmission.
Nov 06, 2012 | Cars & Trucks
Can a 2000 kia sephia transmission be removed without taking the transaxles and exhaust line off?
when in doubt , thank politely and go some where else to an accredited service shop that has experience on your make of vehicle
on assembly the power train ( engine and transmission) is on a stand and the body is lowered down over it and all of the subframe bolts are screwed in
so yes it is possible to remove the power train complete but as that would be the quick way to do it
I suspect that something more sinister is afoot
did you get a detailed explanation of the transmission problem or axle problem or was it just "you need a new " comment
May 01, 2017 | Kia Sephia Cars & Trucks
Vehicle idles poorly. Dies after waiting at stop light. Dies when placed in reverse. Vehicle in the last year has gone through 3sets of spark plugs and wires, 3 distributor caps and rotor buttons, 4...
has fuel filter been changed- try this first if not , then i would look at the catalytic converter- if no exhaust out can cause poor idle,misfiring and burnt up ignition parts
Jun 03, 2011 | Chevrolet 1500 Cars & Trucks
I have a 2000 all-wheel-drive, the rear drive shaft is broken. I can't find the manual that covers Chrysler all-wheel-drive, it looks like the ABS monitor in it, and something from the transmission...
place a jack under the transmission and raise it a bit unbolt (the transmission mount) "i think thats what u mean its all i know that above the transmission holding it in place. You'll need a rachet wrench for this and a long onbe at that,, if not you can use a piece of pipe,, you'll want the extra power.. Unbolt it and lift it off,, if its still too tight jack the transmission up a bit.That providing your refering to the transmissing mounting rubber Which is all i can think you man its the only thing above the transmission. The ABS is 2 parts ,, its a mastercylinder and a booster. Its mounted on the firewall (its the thing you pour brake fluid in.) Unjack any wire or hoses by unscrewiung them and pluging them with something.. DUCT TAAPE or rescue tape works.. Unbloth both the mastercylinder and booster from the firewall... unmounting the drive shat.. well you'll see where it bolts ,, front and back.. Thats the easir part.. you will heed o happer, pull and tug the shaft until it pops out.. Hope I was helpful.. if you need more help please feel free to ask.
Mar 08, 2010 | Chrysler Town and Country Cars & Trucks
How do i overhaul the trasmission of dodge caravan 2002
YOU NEED TRANSMISSION MANUAL AND A HAYNES REPAIR MANUAL.YOU WILL NEED A BASIC TOOLS.2 JACK STANDS FLOOR JACK TRANSMISSION JACK.TORQUE WRENCH.YOU NEED TRANSMISSION TOOLS FOR REMOVING AND INSTALLING SEALS AND BUSHINGS.YOU NEED TOOLS LIKE SPRING COMPRESSOR FOR THE FORWARD CLUTCH ASSEMBLY ALSO DIRECT CLUTCH ASSEMBLY AND LOWER REVERSE CLUTCH.THERE MORE TOOLS INVOLVE.CHEAPER TO BUY REBUILT TRANSMISSION THAN OVER HAUL.
Nov 12, 2009 | 2002 Dodge Caravan
04 Navigator gear shift button broken
I only have 2003 Nav procedure. Maybe get used part at car-part.com. Page with * is lowest price.
SECTION 307-05: Automatic Transaxle/Transmission External Controls 2003 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION Selector Lever —Floor Shift Removal and Installation
  1. Lift the floor shift PRNDL bezel.
  1. Disconnect the PRNDL bezel wire harness connector.
  1. Remove the shift lever handle and cover.
    1. Slide the handle bezel down.
    1. Remove the screw.
    1. Disconnect the TCS wire harness.
    1. Lift assembly from the shifter lever.
  1. Position the window regulator control panel aside.
  1. Remove the screws and the console finish panel.
  1. Remove the left side console access panel.
  1. Disconnect the transmission shift cable from the transmission selector arm.
  1. Remove the transmission shift cable retaining clip from the floor shift mechanism through the console access.
  1. Remove the four bolts retaining the floor shift mechanism to the floor.
  1. Disconnect the floor shift mechanism wire harness connector.
  1. Remove the floor shift mechanism from the console.
  1. Remove the brake shift interlock actuator, parking brake release mechanism and harness.
    • Remove the wire harness retainers.
    • Remove the two screws retaining the brake shift interlock assembly.
    • Remove the two screws retaining the parking brake controller.
Mar 15, 2009 | 2004 Lincoln Navigator
Solution to 2002 Toyota Prius transmission problem
I don't know where you got the price quote,but a new one will be $3700 (Then you will need to pay an additional $350 for installation)
A rebuilt is $3300 (Not including removal and reinstallation)
A used one if you can find one will run about $1750 (then you will need to pay an additional $350 for installation)
You can check new,used and rebuilt price here
Give me you state and zip and I will find a local shop that can do it.
Please rate this a fixya
Feb 04, 2009 | 2002 Toyota Prius
1998 dodge avenger tranmission control solenoid
Below the link for Chrysler/Dodge auto-transmission manual
http://www.scribd.com/doc/7095618/545rfe-Transmission-Manual
Solenoid mounts outside the transmission, so you do not need to remove the transmission to install. It should be located between fuse box and air filter housing on the top of transaxle case and right next to transmission controle module.
I hope his step by step procedure will work for you. It is not hard at all to replace the solenoid. There are three 10mm bolts. You will also need to remove the input speed sensor. One thing to look out for is not bending the gasket when installing the new solenoid:
  1. Disconnect battery negative cable.
  2. Remove air cleaner assembly.
  3. Remove electrical connectors for transmission control module (please refer the manual I send you and autozone.com website).
  4. Remove the Transmission Control Module
  5. Disconnect and remove the input speed sensor
  6. Disconnect the transmission oil cooler lines. Cap off hoses and fittings to prevent foreign matter intrusion.
  7. Disconnect the solenoid/pressure switch assembly connector.
  8. Remove the three solenoid/pressure switch assembly-to-transaxle case bolts
  9. Remove solenoid/pressure switch assembly and gasket
Keep everything clean to prevent foreign materials to go inside
  1. Install solenoid/pressure switch assembly to case using a new gasket
  2. Install bolts and torque to 13 N·m (110 in. lbs.)
  3. Install 8-way connector and torque screw to 4 N·m (35 in. lbs.)
  4. Uncap and install transmission oil cooler lines.
  5. Install input speed sensor and torque to 27 N·m (20 ft. lbs.)
  6. Install Transmission Control Module
  7. Install air cleaner assembly.
  8. Connect battery negative cable.
P.s. 1. You can fine some clips on YouTube.com at least for similar cars
2. Also at Autozone.com you can find the component location for your car and repair guide
3. Also there is a link for Mitchel1 online manual useb by US mechanic 1 week subscribtion is
11.99 , 1 month 16.99
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Let me know if you need more info
Good Luck and happy fixing
Jan 22, 2009 | 1998 Dodge Avenger
Car Audio & Video Logo
11 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
