Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
My Yamaha rx v465 has a message that says "decoder off" for the hdmi channel. I get picture fed to the monitor but no sound to the speakers. No speaker icons appear on the hdmi display. Speakers work with the tuner.
  • btwebpurchas Sep 07, 2010
    I did a temp fix of setting the output to TV and amp and it sent the signal. I will try the fix.
  • 857 Answers
Check the settings on your source device, it may be set to send audio as PCM over HDMI, you need to set the audio output on the source device to bitstream or raw.
Note if you are using the original PS3 you need to leave it on PCM as it can not bitstream the HD audio from Blu-ray(the new PS3 slim can do this).
Also Check your PC is really output 5.1 or 7.1 via hdmi.
Posted on Sep 07, 2010
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha av Receiver RX-V465 picture but no sound. Can switch between PS3 and sat tv all via hdmi connections. Good picture yet still no sound. Trying to run left right and center Bose speakers. Read the...
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
Jul 04, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Haveing trouble syncing the sound with lips is there a trick to do this? also whats the best setting to get the best true surround sound by the way i have Rx-v465 with klipsch 300 home theater speakers.
RX-V465 has auto-sync feature over HDMI. So if you have your DVD and TV connected over HDMI, receiver will communicate with your TV and set the delay automatically based on TV processing speed.
You can turn auto-sync on in Setup menu / Sound Setup / Lipsync / HDMI Auto.
Or if that doesn't work for you, you can set a value in milliseconds manually in the same submenu.
Jan 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
How do u know if the decoder for dd and dts is working
When listening to digital source (HDMI or spdif optical/coax), press Option button on remote and choose Signal Info submenu. There you can see info about number of channels, bitrate and decoder which is currently used.
Jan 04, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I need to use my TV as the speakers for my system..what is the setting on the Yamaha RX-V465 to do this?
For what do you need receiver if you don't want to use its speakers?
As far as I know this is only possible for HDMI connections (when you have your DVD player connected to HDMI-in of receiver, and HDMI-out to the TV). Go to Setup menu / Func. setup / HDMI / Audio. You can choose there if audio from HDMI should be output on receiver's speakers, or TV speakers, or both.
Sep 10, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
2,452 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
