Question about Sony CASSETTE DECK Single Dual Cassette Deck
Wr565 - both decks jam the tape when i play them. any suggestions?
    Novelist:
  • 85 Answers
Rss13506,
I'm not sure what you mean by jam but I bet you need to clean the head, roller and pin in each deck. Use rubbing alcohol and a q-tip to clean the:
1) Head (silver thing in the center bottom where the tape slides over; it produces the sound).
2) Roller (black wheel thing that keeps tension on the tape).
3) Pin (above the roller-works with the roller).
If any of these parts are dirty the deck will eat up the tapes. Clean them even if you do not see visible dirt on the q-tip as dust does not show as well as oils in the air typically from cooking will gum up the parts. Give them ample time to dry before trying a tape.
As any tape playing person knows from the 70's and 80's-try a tape you don't care about first, to make sure the deck will not eat up the ones you like!
-Chris
Posted on Sep 07, 2010
Denon drw585. Both decks will not close with tape inserted. No other signs of life except light in rear of cavity. Roller mech seems to be blocking tape entry. Is it a sensor switch/arm? Thanks.
It seems to me that the mechanism has got stuck in play mode, or at least was ready to go into play mode. It's either down to a cog mechanism that moves the parts into place and has become jammed, or that a belt that moves the mechanism forward has come off.
Apr 12, 2016 | Denon Audio Players & Recorders
The device can't turn on
It is hard to tell you what is wrong with the unit unless I look at it- there are just too many variable. Anything from a defective power supply to a bad power switch.
Aug 30, 2015 | Sony TC-WR565 Dual Dolby Stereo Cassette...
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
BOTH doors jammed on TC-WE605S
Some tape decks are belt-drive. If the belt is worn, it will either break or jump the cog and you will experience these kinds of problems. That's what happened with my Sony ES deck recently and I couldn't even eject the tape until I got the belt replaced.
Jul 30, 2009 | Sony Audio Players & Recorders
Tape deck jammed
I had a tape jam and had to send it to a service center (Pro Tech Service Co, Idaho Falls). They got the tape out, cleaned it, and aligned the heads.
Sep 05, 2008 | Aiwa CSD-NS1 Shelf System
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Jan 01, 2008 | Audio Players & Recorders
121 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
