Question about Dirt Devil Vacuums
Its over heating what does that mean - Dirt Devil Vacuums
    New Friend:
  • 50 Answers
Clean all the possible parts that has dirt
Posted on Sep 07, 2010
Electrolux 6500 sr what do the symbols on top of the canister mean when they are red?
the red symbol probably is the temperature light.This means you motor is over heated.Check hose,wand and power head for a block...Chris
Jun 06, 2014 | Electrolux Epic 6500 Vacuum
I have not used the machine for a while. When I did, a thick pasty substance emitted from the bottom steam vents onto the pas when steaming the floor. What does this mean and how do I correct?
Run a little vineagar and water solution through it. Then all you should run in the machine is distilled water so you dont get that residue and mineral build up on the heating element.
Jan 27, 2014 | Euroflex Monster Floor Steamer
HOOVER Freespace TFG 5123 - Red Light?
Check the entire flow path from intake to bag. You may find it is clogged.
Dec 12, 2013 | Vacuums
My shark steamer is not heating or steaming
I posted this video explaining how to clean the heater core.
http://youtu.be/S4NglGXVv50
Tons of water on the floor might mean that an internal hose or hose clamp has failed. Once you have it apart you can assess and replace the hoses by taking the bad hose to the auto parts store and asking for an appropriate sized replacement.
Dec 18, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover f7411-900 steamvac dual v, water heating unit repair
The element is burned out or the sensor is shot. When there is no water present a sensor is supposed to turn off the heating coil. This sensor is most likley fail safe, meaning if it is broken it wont turn on the heat because it doesn't know if there is water or not. Or the coil itself is fried. Somtimes running it for too long, or on a long extension cord will cause them to fail.
Oct 08, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Euro-pro shark s3325 will not heat up
Sounds like you got stuck with NOS item. New Old Stock. Happens a lot and if you can find that receipt be sure and try to get a refund or another one.
Many items have a date code stamped on them or a manufacturing date on the box, try to buy new or don't give full price.
As for another brand, I like Bissell but don't know if they make something like this.
Oct 06, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I can't find my manual for the EcoQuest Safehearth heater, it is showing a E2, I don't know what this means, which then it s not heating. help please
E2 means that the heater senses that it has been tipped over. Unplug it, wait a few minutes and then plug it back in an try it. If the problem persists there are 3 capacitors on the control board in the front of the unit that go bad causing the symptom also. They are tall cylindrical parts that look like short aaa batteries. They are rated at 1000uf 25 volts, 105 degrees C. You can find them on ebay or Digikey.com for a couple dollars each. You will need to solder them in. Pay attetion to polarity so you don't put the capacitors in backwards. That should take care of it for you!
Jan 14, 2011 | Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Unit will not run
I DON'T KNOW WHAT YOU MEAN BY "F/C" LIGHT, BUT IF THE MACHINE IS OVER HEATING THE LIGHT LOOKS LIKE A THEMOMETER. IF OVER HEATING IS THE PROBLEM, ONCE THE MACHINE COOLS IT SHOULD WORK AGAIN.
Aug 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
377 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
