Question about Kettler Stockholm Outdoor Table Tennis Ping Pong Table
I have a havard ping pong table that has a few scratches, is there a touch up kit that i can purchase to cover the scratches?
  • 2006 Answers
SOURCE: Out Kettler outdoor ping pong
Glue is heat sensitive, so you might try a DAMP towel and a iron. Followed by phone books to hold it steady while drying.
Posted on Jul 10, 2011
SOURCE: Have an old Kettler ping
Same problem with mine. Also I can't get the table to align properly.
Posted on Dec 27, 2009
HondaCRX
  • 252 Answers
SOURCE: how do i restore the surface of my outdoor ping
Use painters tape to cover the white lines of your table tennis table.
Use sandpaper (150grit) to smooth the surface. This will level any bumps or scratches. Fill deep cracks with wood filler, let it dry and sand the table again.
Make sure that the table is clean before you begin the painting procedure.
Use chalkboard spray paint about 8 inches away from the table and spray each side. Allow 8 hours for the paint to dry then repeat with another coat. Next day, repeat the process so you have 3 layers of paint. Chalkboard spray paint helps the ball bounce to the correct height and speed.
Remove the painters tape after the last coat and allow the table to dry for at least 24 hours.
Hope this helps, vote me if so :)
Posted on Jul 03, 2010
SOURCE: how to put together the ping pong
what are the parts that go to the ping pong table
Posted on Oct 21, 2010
tbreeze47
  • 3083 Answers
SOURCE: My Kettler Outdoor Ping Pong
I couldn't find anyone on the net that rebuilds these devices, but I found what looks to be a good discount site, and you might check it out- here it is:
http://www.robbinstabletennis.com/k_7122_gi_feat.htm
By the time you go to the trouble of trying to get replacement parts, and labor rebuilding it, you might be better off getting a good one at a good price.
You could call around at some furniture repair shops, and they might know if anyone does this kind of repair locally.
Good luck to you, and hope this helps.
Posted on Nov 17, 2010
How can i protect my furniture and table from my grandchildren's obsession with ping pong?
On the Monkey Business Sports website there is a product that might interest you.
It's a table tennis set called Top Spin, that allows to safely play ping pong indoors without damaging furniture.
The set includes two soft ping pong balls and two soft foam paddles that prevent any furniture and table damage, and a net divided in three sections so that it can be set anywhere, allowing you to pick your grandkids' game location. The whole set comes in a small bag of the size of a loaf of bread, which makes the set even more easily packable and portable.
They would probably appreciate the present and effort and you would make sure that no wooden paddles will scratch your table.
I still would suggest hiding the china though
Nov 28, 2013 | Toys
How do I properly clean my ping pong table?
Cleaning your ping pong table may be a daunting task, but a worthwhile one in my opinion. I found you a great 5-step guide to having your tables clean in no time.
http://www.livestrong.com/article/180843-how-to-clean-a-ping-pong-table/
Jul 29, 2012 | Sport & Outdoor - Others
I would like to attempt to build my own ping pong table for our home. Can anyone send me a guide that will help me with this project?
In my opinion, you may want to rethink this strategy. Although building the table yourself will be less costly and provide you with satisfaction, it is not a good idea. In my opinion, even the cheapest made tables on the market may cost similar to what you would spend on materials and will still be constructed better (no offense). Ping pong tables are very difficult to construct properly and require a lot of skilled work. However, if you are still set on building one yourself, I will provide you with a few links that may be helpful.
http://www.essortment.com/table-tennis-build-ping-pong-table-scratch-49822.html
http://www.instructables.com/id/How-to-Build-a-Ping-Pong-Table/
What can I do to extend the lifespan of my ping pong table?
You should look into buying a cover for your table for when it is not in use. If you have an indoor table, your options are endless; however if you have an outdoor table, I highly recommend getting a waterproof cover. I will send you a few links with a variety of covers for your table.
http://www.sportsauthority.com/product/index.jsp?productId=11645315
http://www.robbinstabletennis.com/tabcov.htm
http://www.ebay.com.au/sch/sis.html?_nkw=NEW+WATERPROOF+TABLE+TENNIS+PING+PONG+TABLE+COVER
How thick should the surface of a ping pong table be?
The best thickness for the surface of a ping pong table top is between 25-28mm thick.
How should I be standing when playing ping pong? What do I do with my body?
A good ping pong stance consists of a slight crouch forward and placing your feet shoulder-width apart. Make sure that your knees are bent. Most of your weight should be on the balls of your feet, allowing you to move with speed. Your upper arm should be close (not flush) to your body and your forearm and racket should point forward. In reference to the table, you should be standing so that the tip of your paddle barely touches the edge of the table.
How do i restore the surface of my outdoor ping pong table
Jun 30, 2010 | Kettler Stockholm Outdoor Table Tennis...
Kettler Stockholm Outdoor Table Tennis Ping Pong Table Logo
604 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
