Question about Maytag Dishwashers
My Maytag model MDB4100 AWB fills up with water but does not clean the dishes. It is though it it not shooting high pressure water like it used to. I thought maybe it was the water inlet valve but the the dishwasher does fill to above the heater coil. Our dishes have not been getting clean for about two weeks. What other parts should I be suspecting?
catriver
  • 878 Answers
SOURCE: Kenmore dishwasher 665.1671590
Your inlet hose probably came loose on the left side of the dishwasher. If you pull the d/w out 6 inch. or so you will see the s-shaped hose going to the inlet port on the tub. Make sure it's not pinched or leaking..Catriver
Posted on Jun 07, 2006
  • 145 Answers
SOURCE: Door Interlock switch Maytag MDB4100 dishwasher
If the door is not latching well enough try adjusting the spring on the tub it's the male part that goes into the door latch. If that doesn't help you need to replace the latch. It's inside the door. The switch is mounted to the latch in the door so to get to it you have to remove all the screws around the outside edge of the inner door panel. Unhook power before replaceing latch or switch!
Posted on Apr 23, 2008
abhishek33
  • 1239 Answers
SOURCE: Dishes not getting clean in GE Triton XL Dishwasher
HI
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Posted on Oct 12, 2008
SOURCE: Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Posted on Dec 13, 2008
lojacksdad
  • 121 Answers
SOURCE: After cycle, there is grit on my dishes
they are in your water valve very hard to get to have you switched to liquid soap much better
Posted on Apr 17, 2009
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Dishwasher will fill up with water but wont clean dishes.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
It is just not cleaning the dishes. Runs - OK
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
Daniel
Dec 13, 2010 | Maytag Dishwashers
Have a white film all over all my dishes and silverware
Hi
Daniel
Nov 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
My dishwasher is filling up with water but it is not cleaning dishes. the lower spray arm is moving but has limited pressure. The top sprayer is barely moving. Water gets hot but seems as thought the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
agf23
Sep 06, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
I have a frigidaire ultra quite modle number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of presure?
Hi, lilztheman
You said,
I have a Frigidaire ultra quite model number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of pressure?
And is the water inside your dishwasher and cleaning your dishes??
Please clarify what the problem is and what's wrong.
Where is it shooting pressured water too?
This dishwasher has the older tower type spray system inside the dishwasher.
It consists of a number of tower like tubes that fit one inside the other by the water pressure and they all are pushed up into each other to create a tower which sprays the dishes clean with high pressure water.
At the top of the tower is a plastic cap to direct the water with pressure in all directions!
Please tell me in detail what the problem is so I may suggest a solution.
Sep 17, 2008 | Dishwashers
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
