Question about GE WBVH6240F Front Load Washer
I have a GE WBVH6240FWW. The start/pause button is blinking and won't start the the wash cycle. When you push the start button the washer beeps. With this issue I can not get the service mode test to start.
  • 6,784 Answers
HI. What you are experiencing at this time is a basic control fault that may be easily corrected by a hard reset. This procedure consist of simply unplugging the unit for five minutes, then plugging the unit back into the power outlet after the five minutes have passed.
Now; If the hard reset does not produce positive results, this will confirm that the power relays have failed. These relays are mounted on the main control board. This severe damage will require you to have the entire main control assembly replaced, asap. The necessary part number for your new replacement control assembly will be WH12X10355. Click on the part number to be directed ot the purchase page. To help guide you through this necessary repair detail, i have posted the proper service manual for your unit below this text. Click on that link to download the entire manual to your web browser. I would advise to save the PDF file to your HD, for safe keeping and future use.
GE WBVH6240FWW SERVICE MANUAL
Posted on Sep 06, 2010
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Washer model wbvh6240fww will not run. The settings come on but when the start button is pushed, washer just beeps.
press and hold the button for at least 5 seconds and it should work.....hope that helps
Aug 30, 2008 | GE Washing Machines
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WBVH6240F Front Load Washer Logo
941 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
